Canister Control Valve? What does it do?
PeteA216
11-12-2005, 11:54 PM
Hey everyone... does anybody know what the canister control valve is on the emmission system in my '84 Caprice? What does it do? What would happen If I were to remove it and block off the hoses so I wouldn't have any vaccume leaks? This is just a "curiosity" question, but any info would be greatly appreciated. Thanks everyone!
silicon212
11-13-2005, 01:59 AM
Without it, you will have a gasoline vapor issue - you will smell gasoline basically all the time with it.
I've had one fail before and it resulted in the carb bowl being filled with charcoal from the canister - resulting in the need for a new E4ME carb - and a new valve. While it was failed, as a quick fix I pulled the carb apart and cleaned as much as I could out of it and blocked off the valve. I had the vapor issue I detailed above.
If you're having vacuum leaks, it's best to replace the hoses and leave everything as it is.
PeteA216
11-15-2005, 10:45 AM
Thanks for the quick reply... I spoke with my neighbor (he's a mechanic at doan) and apparantly the charcoal canister has been in cars for years; before emissions even really came into play (aside from the EGR & PCV valve). It looks like I'm just going to have to deal with all these hoses clustering across my engine. I was kinda trying to eliminate the "rubberband engine" look.
cyclonicblade
11-24-2005, 11:55 PM
You can extent or decrease the lenth of the hoses to an extent and dress them with a wire loom wrap to hide them or reroute them to clean up the clutter in the engine bay
PeteA216
11-25-2005, 11:05 PM
Thats what I'm trying ta do... get rid of the clutter. I like the look of pre-emission engines where it was simple looking, hardly any hoses or wires going everywhere.
cyclonicblade
11-25-2005, 11:32 PM
yea , you can do that. get a vacum line map or draw one your self take and pick a route from the engine. to the firewall or each fender well and reroute each line along the chosen path but branch out like a bean sprout. when all lines are where you want them cover them with a wire loom wrap avail at most auto part stores (Junk yards have miles of the stuff) at each branch you can use a small gauge wrap. joined with elec. tape. cleans up the bay and gives it a custom look. just keep it away from the EX. manafolds and when doing hoses like the canaster use the right hose. it's not a vacum line. its a fuel vapor line. it would prematurely dryrot a normal vacum line.
PeteA216
11-26-2005, 03:46 PM
Thanks for the tips! I'll get working on rerouting everything. Now what about the large cluster of wires coming from the ECM unit and spreading out throughout the engine (Inside a massive piece of loom). Do I cut the wires, extend them, and reconnect them? Thanks
cyclonicblade
11-26-2005, 04:27 PM
i would try to get them all tucked in the loom and covered to see how it looks . the problem u will have with some of the sensors is that 1. any splices will need to be soldered. 2. the computer is expecting a set base value from each sensor change the leinth of wire too much u change the resistance so work in baby steps. 3. draw a map in case your memory fails. and when doing any work on the elec. system disconnet batt.
