Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Impala / Impala SS
Old 11-12-2005, 08:06 AM   #1
GB19545449
GB19545449 Normal reputation
sludge
what does it mean when you pull the radiator cap and find this
brown colored sludge around the neck . Is it manifold gaskets , head
gaskets, cracked head, or a bad radiator leaking trany fluid! This is a
3.4 engine in an Impala.
GB19545449 is offline   Reply With Quote
Old 11-12-2005, 10:56 AM   #2
thermal izod
thermal izod Normal reputation
Re: sludge
time to flush/replace the coolant....dexacool strikes again
thermal izod is offline   Reply With Quote
Old 11-12-2005, 11:43 AM   #3
maxwedge
A990 racer
maxwedge Normal reputation
Re: sludge
Some of this seperation can be normal in small amounts on the cap. Look down in the radiator cores to be sure and change the cap also, any poor sealing of the cap can also cause this.
maxwedge is offline   Reply With Quote
Old 11-12-2005, 03:56 PM   #4
thermal izod
Re: sludge
max: good call.
Old 11-12-2005, 09:11 PM   #5
simonswu
simonswu Normal reputation
Re: sludge
Why I could never open up the radiator cap on my impala? turned cap to the release position, then pull whatever so hard, just can't...
simonswu is offline   Reply With Quote
Old 11-12-2005, 10:22 PM   #6
bigrod118
bigrod118's Avatar
bigrod118 Normal reputation
Send a message via AIM to bigrod118 Send a message via MSN to bigrod118 Send a message via Yahoo to bigrod118
Re: Re: sludge
yeah, I thought I was doing wrong too, just run it until it stops, then you have to push down and continue to turn it, thats how you have to take off allradiator caps, except the impala one, is really really hard to puch down far enough to finish turning it off, I had to use two hands and some body weight.
bigrod118 is offline   Reply With Quote
Old 11-13-2005, 04:25 PM   #7
simonswu
Re: sludge
with the advice I finally managed to open up the cap. Well.... sludge!!! but not much, about 1/8" thick inside the cap and around the neck. It's pretty oilly. As far as I know the dexcool is much like oil, right?
Anyway I'm going to get a coolant flush with upcoming major maintainence. Had head gasket replaced about a year ago. They just mentioned "changed milky oil", but not coolant.
Were they supposed to do something to the coolant side in the common "head gasket" cases?
Old 11-15-2005, 10:53 AM   #8
TMURPHY1
TMURPHY1 Normal reputation
Normally the sludge you refer to at and around the radiator fill neck is remants of the coolant system sealant that is put in at the factory when new. It is similar to the kind you might find at your local parts store and is normal in small amounts around the filler neck. Wipe out neck and either flush or top off. Otherwise if your coolant is totally contaminated a blown intake gasket is likely.
TMURPHY1 is offline   Reply With Quote
Old 11-16-2005, 12:42 AM   #9
simonswu
Re: sludge
you could be right for mine. The "sludge" is much like old deposit of plumber sealant I saw when taking apart household drain pipes.
Bookmarks
Google
Web AF
