1999 malibu cranks but wont start
joneslt
11-12-2005, 09:03 AM
already replaced coil pack and wires
maxwedge
11-13-2005, 11:09 AM
Spark, fuel pressure, will it run if you spray carb cleaner in the intake?
mobil_12
11-13-2005, 11:14 AM
max is right, check the basics first. spark, fuel, compression and timing, thats all you need. (sorta) new coils and wire should spark good, but are the being told to fire? could be a crank sensor. check fuel pressure, could be a bad pump. you need a direction to go.
