95 auto no reverse?mlw35405 11-12-2005, 04:52 AM Friend's truck, 95 Automatic, 4 cyl, 2wd, 110k miles. Reverse went out yesterday. All other gears shift fine, but reverse does nothing. I was thinking maybe a solenoid in the tranny, but I'm a Ford guy and don't know much about Nissans except that I find them hard to work on. I wouldn't think it would need a tranny replacement with only 110k. If you could give me some ideas maybe I can help her (and get a date!!). swiftknight23 01-23-2008, 02:23 AM its probally a faulty clutch or a faulty band First, if this vehicle's transmission has bands and further, if they are the type which can be adjusted (not all are), have them adjusted... this should help so long as each band's lining hasn't worn too much. Otherwise, the bad news is that you will be facing a costly repair if the drivetrain is no longer under warranty. Also, every garage in town will tell you they'll need to do a transmission teardown in order to determine the exact cause of the problem. They'll be right too. Why? Because it's just impossible to know for sure what the cause is until the transmission is opened up. Automotive Network, Inc., Copyright ©2012
