How do I make my A/C much colder???
Rapidito
05-28-2002, 08:30 PM
I've got a 1992 Civic CX hatch and the a/c isn't that cold. It's ok but it could really be much colder. I mean hell, I road in a Geo Metro that blew colder than this and it's getting hot here in New Orleans. I've noticed that many 5G Civics have pretty weak a/c systems. How can I make it colder?
iLLuCiv99
05-28-2002, 08:41 PM
Have you checked the coolant? :confused: What do they use now? RU135....
sparq
05-28-2002, 09:43 PM
Go have it checked out, probably needs a recharge... or it may not have A/C just a nice little fan that blows air in your face :finger:
Rapidito
05-29-2002, 09:41 AM
The 5G Civic uses the older, more expensive coolant. What do the newer cars use now? I think it's called R-12.
Pilot
05-29-2002, 02:44 PM
I've been in an old civic...like ~90s and the air contitioning made the car like a freezer. I think those are out because they pollute or something
JayFidizzy
05-29-2002, 05:26 PM
the new coolant is just as good....i had to have my last car converted to the new coolant. It was still just as cold..if not more. I would get the coolant refilled and make sure your ac unit is running properly.
RTYPE!
06-01-2002, 01:22 PM
Coolant goes in the radiator,Freon goes in the A/C system.Cars pre about 95 used r12 freon,newer cars use r134.R12 freon is very expensive because the government does not allow its production.A typical cars uses about 3 pounds of freon,an r12 recharge will probably cost over $200.Have a professional mechanic convert your system to r134 and you will be a happy camper.:)
Ebranste
06-02-2002, 05:29 PM
He wouldnt necessarily be happier. Converting to R134 requires more than just a recharge with R134. If he's using a stock compressor, its gotta be swapped for one that R134 compatible, and once that's replaced, you still have to fluch out the system and replace a few more parts as well, some a little more costly than others.
I know this cause I converted my '88 to R134 myself. It was a good experience, but if your goin gto have this done at a shop, you're gonna pay somewhere around $1000, probably a little more if you dont have a local 'hook me up' guy.
If it is low on freon, and needs a recharge, something you need to realize is that it has a leak somewhere. Otherwise it wouldn't need a recharge. Freon does not break down and dissipate through the AC lines.
Only get a convertion done if you are going to keep the car around for while and want ot save money on future AC work should it become necessary.
Rapidito
06-07-2002, 03:45 AM
Thanx for the info. I don't think I'll do a conversion just yet. I did a price check and it was about a G...too much if the a/c is running ok. Maybe in the future when I get another car I'll see about learning to do it myself. But thanx yall.
