windshield washer problem
96accordboi
11-11-2005, 12:46 PM
i filled my windshield washer fluid tank up and when i try to use it nothing comes out i looked for leaks but couldnt find any, any ideas on what could be wrong also my car is a 96 accord lx, when i bought it, the car had like some left after i used it up i havent fefilled it untill now and it doesnt work :( so im thinking some of the wires are clogged and maybe i need to change them, how hard would that be?, any other solutions would be nice thanks
AccordCodger
11-11-2005, 01:54 PM
Some punctuation and capitals would make your post a LOT easier to read.
Could be clogged nozzles (athough I dobt NOTHING would come out) or your pump/wiring/fuse may be at fault.
96accordboi
11-12-2005, 01:54 PM
and where would this pump be located any info would be nice thanks
jeffcoslacker
11-12-2005, 02:43 PM
Pull the tubing off the nozzles and see if it comes out when you hit the spray.
If so, take the nozzles off and blow backwards through them. Usually a big wad of crud will spit out, then they work fine.
If you still get nothing, your pump might be bad. Do you hear it when you try to use it?
AccordCodger
11-12-2005, 08:00 PM
Don't recall where the pump is located, though you COULD follow the tubing. But do what Jeffcoslacker said first, and listen.
And PLEASE use capitalization and punctuation.
96accordboi
11-14-2005, 01:17 PM
Ill try the first solution, but I Think my pump might be broken because I dont hear anything when i use it, thanks for the advice.
jeffcoslacker
11-14-2005, 02:30 PM
Most pumps these days are mounted right in the bottom of the washer tank...
