1993 Accord - problem starting,engine,D4 light
tupun
11-10-2005, 09:02 PM
Hi
I have a honda accord 1993 and 85 K on it. I am having a starting problem when the weather is cold ( arounf 32 F) , I have to try 4/5 times then it starts. The engine check light comes on and D4 indicator blinks. I have to press on gas for 1 min or so , then turn it off . Restart it , it runs fine (no engine light or D4 light). If I park the car in the parking lot for about 8/9 hours then the problem re appears .
When the weather is not so cold the car has no problems!!!!!!
Can somebody help Please to find the cause.....
Thanks in advance
Tupun
tupun
11-12-2005, 03:10 PM
Today I checked the code , it is 6 .Coolant Temp Sensor. Not sure why D4 is blinking, any Idea please ?
trimmer
11-20-2005, 08:20 PM
its ur main reaily, i just had mine replaced. its up at the top of the dash on the driver side its costs about 70$. starts every time now. it contols fuel pump and ignition.
mpumas
11-22-2005, 01:38 AM
D4 blinking is a TCU issue. Does D4 blink even when the shifter is not in D4? If the ECU light comes on, a code is stored in memory indicating why it came on. If the light goes off it means the problem went away, but the orginal reason it came on is still stored.
tupun
11-22-2005, 10:02 AM
Thanks a lot for reply, did your problem happened in cold. I face problem when the weather is cold , in warm days it is OK
Regards
Tupun
tupun
11-22-2005, 10:05 AM
Thanks a lot, yes D$ blinks when in parking also. The engine ckeck also shows at the same time. I have to drive the car for 1/2 mins . then restart and both lights goes away
Regards
Tupun
mgcatthew
11-22-2005, 02:31 PM
considering the harsh temperature where you live, have you recently bought a new battery. if it is pretty old the car will take longer to start. the proper cold cranking amps will help in the cold weather. now with the shift light blinking, you can do either two things or both. have your tranny flushed and your radiator flushed as well. i had the same problem arise in my 92 lx and it fixed the problem. it is scary to see that light flash but turning off the car and giving it a few seconds to reset itself is all it takes. Before you start it up just turn on the accessory lights and see if it blinks or not. the relay is for the fuel pump and the bushings getting deformed in high temps because it is under the dash (the hottest part in the cab)
mgcatthew
11-22-2005, 02:34 PM
oh forgot on more thing. with the starting problem, it is possible that your ignition wires could be swelling, and the ignitor could have enough wear and tear on them to be affected by the cold and are not getting enough juice to fire the engine
trojan84
10-17-2008, 01:22 PM
So did you fix the problem? If so, what is that fixed it?
