Ignitnion harness?
drummerfor440
11-09-2005, 06:36 PM
ok so i bought a remote starter for my 90 caprice cuz im too lazy to wake my ass up in the freezing cold to start it. only problem is i need to tie it in with the ignition harness. so i pulled the panel under the stearing columb but for some reason im not able to identify what is what. because the harness just doesnt look right. does anyone have a pick of where the ignition harness is located and what it looks like?
silicon212
11-09-2005, 08:05 PM
The ignition switch is the first thing on the top of the steering column, just under the dashboard. It's kinda rectangular shaped, with two bolts that hold it down on the left side as you look toward the firewall. The high beam switch is mounted to the column on the left side in roughly the same place and the two share a screw. The harness attaches to the ignition switch on the right side as you look at the firewall. The neutral safety switch is closer to the firewall and is on the top with wires plugging into the front of it as you look at the firewall.
drummerfor440
11-10-2005, 04:02 PM
thanks alot, that really helped me out, i ended up droping the stering wheel to get to it, but its in and it works, two more things i need to find are where the parking light wires come in and witch wire is the positive on the break switch.
