Timing chain problem
57r337.Dr1f73r
11-09-2005, 01:01 AM
Ok I just bought my first car a 93 240sx, and I am having a couple problems with it.
My timing chain is rattling around idle, I think that the chain is too loose. I have already removed the upper guide mounted between the cams by two bolts.
I am going to replace the chain, should I replace the sprockets too?
I would like to avoid removing the head.
How would I go about timing the engine?
And lastly has anyone driven with JIC or Megan coilovers I would just like to get some feedback before deciding which ones to get (i'd like to stay JDM if I can).
Thanks for all your help.
slideways...
11-09-2005, 01:05 AM
buy a chilton manual.
you have to pretty much remove the head to change the chain. while you do this, you may as well replace anything else in the area
again, get a chilton manual. it tells exactly how.
and as far as the coilovers...
JIC = gay
Megan = JIC's gay retarted crackbaby
get silkroads
57r337.Dr1f73r
11-09-2005, 03:29 AM
I have the factory service manuel
I was talking about replacing the upper chain I know to replace the sprockets I would have to unbolt the two cam sprockets and remove the head to replace the idler sprocket
My question was to fix the noise would I be ok just replaceing the upper chain?
and whats wrong with JIC?
57r337.Dr1f73r
11-09-2005, 07:32 PM
I'm not asking how to install the chain I'm asking if I could get away with using the old sprockets because the upper chain is the only problem. I can replace the upper chain without removing the head but I wouldn't be able to get the idler sprocket out.
I was just asking for your opinion.
