Electrical shortage???93tblx 11-08-2005, 03:10 AM I have a problem with some of the lighting and the rear defogger. They work but I think that there is some loose wiring somewhere because for the rear defogger I have to hold down the button for it to function and for my lights on the gear box I have to tap the sides a couple of times to get the Drive, Reverse, etc to light up. Can someone help me out on this? AzTumbleweed 11-08-2005, 06:25 AM You're rear defogger switch is bad. When you hold it down it should lock into the down position and stay on. Best look in a junk yard for another. You could also drill a hole under the current switch and mount a toggle switch. Make sure it's rated as high or higher than the stock one so you don't overload the switch. Sounds like you have a bad bulb connection on your shifter light. You'll have to get in there and probably put in a new bulb with new, clean connections. Automotive Network, Inc., Copyright ©2012
