Clutch adjustment
Ghosty
11-07-2005, 09:55 PM
Hi there can anyone tell me how to adjust the clutch on a 1997 Daewoo Cielo please?
Many thanks Ghosty
Helixdaunting
05-24-2007, 06:39 PM
What do you mean by "adjust the clutch"? Has it run out of hydraulic fluid, or do you want to increase or decrease the pressure required to depress it? If so, you have to replace the clutch mechanism with a heavier/lighter-spring model, depending on your preference. Bear in mind that the force you have to apply to the clutch to depress the pedal directly relates to the amount of force the springs can apply to the clutch plates, and therefore how hard the plates can grip each other, and by extension the amount of power/load the clutch can handle without slipping or wearing out too quickly.
nelson.jones07
11-26-2009, 02:23 PM
Its a simple process which can be done by yourself only. Just check out the process on related links and also you can watch it on you tube.
Samiparker
01-23-2011, 10:10 AM
Ask a mechanic otherwise a little wrong adjustment is much like going for an accident.
