Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > MG > Nonspecific
Old 11-07-2005, 05:02 PM   #1
cwmidget
cwmidget Normal reputation
midget clutch line
Any suggetions on how I should fabricate a new line from the master to the slave. No one has any type of line at the parts store to replace it. Thanks for any help. Chris
cwmidget is offline   Reply With Quote
Old 12-08-2005, 09:04 PM   #2
Hobbes567
Hobbes567 Normal reputation
Send a message via AIM to Hobbes567
Re: midget clutch line
had the exact same problem. i had to have a shop custom make a steel line with the fittings put on. the pipe was straight, so i then had to bend it myself. it was a complete and utter pain in the ass. are you sure nobody carries some kind of flexible line? i chose this because of my budget.
Hobbes567 is offline   Reply With Quote
Old 12-08-2005, 11:38 PM   #3
KimMG
AF - Advisor
KimMG Normal reputation
Try the ProperMg, they may be able to help you out with parts. They are one of many sources I use.
propermg.com I believe this is their website.
KimMG is offline   Reply With Quote
Old 05-02-2006, 08:38 AM   #4
ClearHooter
ClearHooter Normal reputation
You didn't say if yours was a post '74 or not. But if its one of the 1500's with that plastic pressure hose that runs through the firewall; I used to use steel braded pressure hose and it worked better than the factory. If you got a pre-74 I'd say one of the British car suppliers would be your easiest route. They make almost everything.
ClearHooter is offline   Reply With Quote
Bookmarks
Google
Web AF
