11-07-2005, 06:01 PM
95 blazer won't start
hi i have a 95 s 10 blazer and a couple of weeks ago it started taking a while to turn over when it was cold but once it warmed up it ran perfect ,but the other day when i went to start it it would not turn over.. tried a few times over the weekend to start it but no luck any suggestions thanks
11-07-2005, 06:15 PM
Re: 95 blazer won't start
If it doesn’t turn over. Check your battery. Make sure that your connection are good and tight. Let us know what you find.
1994 1st.Gen. S10 Blazer Tahoe
Aloha
Gabe
My Fleet
11-07-2005, 07:33 PM
AF -Advisor
Sounds like your CPI injector is leaking.
Do a search for CPI injector and you will find out what you need to replace.
1995 Factory Blazer Service Manual for sale, PM if interested.
11-08-2005, 08:56 PM
checked battery terminals they were good..the engine cranks but does not start does not seem to be getting the gas or something
11-09-2005, 06:55 AM
Check fuel pressure at the shrader valve... Then check for spark..
11-09-2005, 11:26 AM
Re: Re: 95 blazer won't start
Just to add a little something. You should have around 60 - 65 psi at the shrader valve.
Aloha
Gabe
My Fleet
11-17-2005, 10:06 PM
Re: Re: Re: 95 blazer won't start
I replaced the fuel filter, and checked the pressure, it was 30-35 psis. It safe to say its a bad fuel pump or could it be something else ....thanks
11-17-2005, 10:22 PM
real dumb question I know but,
how do you "check for spark"????
is that where you pull the plug wire boot and hold it close to the plug and check for spark jumping across ???
11-17-2005, 11:14 PM
AF -Advisor
Re: Re: Re: Re: 95 blazer won't start
Your cpi injector, nut kit, or the fuel pump is bad.
You have a 1995, my money on the first two.
11-18-2005, 12:11 AM
I agree with BlazerLT. You should do a leak down pressure test. If your pressure is stable after 5 minutes. I would change the fuel pump. If it not stable and you loose more than 1 psi. You should check your Plenum for washing. You'll probably need to replace your CPI and Nut Kit.
Aloha
Gabe
My Fleet
12-06-2005, 06:27 PM
replaced the cpi and nut kit also while i had it apart i replaced the roter and cap and it still won't start..i brought wires and plugs but haven't had a chance to put them on, but i pulled one of my wires off and put a new plug on just to see if i had spark but had no spark...i'm going to try to replace the plugs and wires tonight but what else could it be...thanks
12-06-2005, 06:29 PM
Check your coil and connections at the ignition module attached to the coil.
12-06-2005, 07:24 PM
thanks .. i took it off and with my meter i ohmed it out and according to the book everything seemed ok what do you think i should check next
12-06-2005, 07:28 PM
AF -Advisor
Hpw about checking to see if there is actual spark coming out of the coil wire first
12-06-2005, 08:28 PM
Don't overlook the two ignition fuses in your fuse panel. That's how our problem began. It progressed to being totally dead (zero spark). If you replace everything in the entire ignition and fuel injection systems, including the vcm and battery, and still have no spark, then you will be in the same boat as me with our '95 s-10 Blazer 4.3W with its "one year only" abortion of an ignition and fuel system. You are well on your way.
I now have to surrender the vehicle to a local shop to put limitless hours ($$$) into tracing every wire in the vehicle harness to find what they, and I, now think must be a busted/burnt/shorted wire... Ah, the garbage being manufactured in the USA from Mexican parts these days...
I'm buying my old '72 Blazer (now THAT's a REAL American truck!) back from my buddy and never buying a computer-chip-n-plastic vehicle again. Junk, junk, junk... Poorly engineered and built even worse. If the computers don't work, the world comes to an end. How did mankind ever make it to this point of utter pathetic dependency on something so fragile and unreliable? Sorry. Am I ranting? I used to love wrenching on my vehicles. These new ones make me want to puke at the mere thought of even opening the hood.
