Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Impala / Impala SS
Old 11-07-2005, 04:58 PM   #1
billyo69
billyo69 Normal reputation
Air Temperature Sensor
What does the AIR TEMPERATURE SENSOR due?Seeing as myprob only happens in cold weather maybe that could be the prob.
billyo69 is offline   Reply With Quote
Old 11-07-2005, 05:17 PM   #2
MT-2500
AF - Advisor
MT-2500's Avatar
MT-2500 Normal reputation
Re: Air Temperature Sensor
Are you having wild dreams?
Just because it acts up in cold weather?
Air tempt. sensor tells the pcm what the intake air tempt. is.
To check it read it out in the pcm with a sanner.
While you are in there check the other readings like eng. tempt. which is different than air tempt. and other stuff and see if it has any codes.
How is your tune up plugs, fuel filter,air filter and fuel pressure and all of the good stuff that makes them run good.
What eng. and mileage?
MT-2500
MT-2500 is online now   Reply With Quote
Old 11-07-2005, 08:57 PM   #3
billyo69
If you haven't seen my other postings here is 1 of them
"Well since it has gotten cold out again my temp gauge is quitting and fans are running constant.It was fine all summer after having the same prob last winter.I have changed sending unit twice I had to change cooling fans because bearings went from running all the time.And its hard to get good heat at 0 degrres with fans running.If i pull the PCM fuse for at least 20 min it will be fine for a while.What part could react to outside temp to cause this.The antifreeze temp and thermo are fine its electrical i think?"
This problem does not happen all summer long it only happens when the outside temp gets below 40 degrees or so at hiway speeds(WIND CHILL)
I paid $80 on a scan to have a dealer tell me that it needs a $500 cluster panel.They say thats what the scan tells them but they will NOT gaurantee that that will solve the problem however they claim that it SHOULD cure my erractic fuel gauge that has recently gone haywire.So i thought that if the air temp sensor was bad it may be the culprit.I just ordered one so i will know shortly.I also ordered a new thermostat even know the one in it is working fine.I also ordered a map sensor to rule that out.I"M GONNA START THROWING $ AT IT UNTIL ITS FIXED OR IM BROKE
Old 11-08-2005, 06:40 AM   #4
billyo69
Its a 3.8 with 150k.Tune up is good.All new filters plugs and wires etc
Old 11-08-2005, 08:19 AM   #5
MT-2500
AF - Advisor
MT-2500's Avatar
Good Luck
I hope you have a big bankroll.
That can get expensive.
MT-2500
Old 11-08-2005, 08:53 AM   #6
billyo69
I used to have a big bank roll .A wife, 3 kids and a fleet of chevys to care of that
Bookmarks
Google
Web AF
