Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Dodge > Neon/Plymouth Neon > 1st Gen 95-99
Old 11-07-2005, 02:36 PM   #1
the_game_rock
the_game_rock's Avatar
the_game_rock Normal reputation
Motor reving
I have a 5 speed and whenever I take it out of gear it will sometimes rev to around 1500 and only go down when I stop or put it in gear. anyone know why??
the_game_rock is offline   Reply With Quote
Old 11-07-2005, 08:29 PM   #2
fasstdak
fasstdak's Avatar
fasstdak Normal reputation
Send a message via Yahoo to fasstdak
Check for vacuum leaks (especially near the PCV valve) and when is the last time you cleaned out your throttle body?
Chrysler/Dodge Certified Technician
1997 Dodge Dakota SLT - V6/5spd CC
Carillo Rods, KeithBlack Pistons (10.75:1), Ported & CC'd Heads, Crane Rockers (1.7:1), CompCams custom camshaft, Mopar Drive Gear, Smith Brothers Pushrods (7.050"), Ported Factory Intake, APS 50mm TB, APEXi SAFC-II Controller, JBA Headers, Magnaflow "TurboXL" Muffler, Cloyes True-Roller/Dbl-Row Chain with tensioner, etc. Dyno Proven: 214RWHP/238RWTQ (Without the Nitrous)
http://www.dodgetrucks.org/fasstdak
fasstdak is offline   Reply With Quote
Old 11-07-2005, 08:34 PM   #3
the_game_rock
Re: Motor reving
alright ill check I havent cleaned out my throttle body. what did you clean it with?
Old 11-07-2005, 09:03 PM   #4
fasstdak
fasstdak's Avatar
You can use your favorite carb/tb cleaner (Berrymans B12 cleaner is what I use at home - BG at work). The best way is to remove the throttle body, remove the IAC Solenoid, and clean both the ports and bore of the throttle body - and the IAC plunger (make sure you do NOT twist the plunger...just spray it down and wipe gently). The IAC (Idle Air Control Solenoid - sometimes referred to as the AIS) controls your idle and will get clogged with carbon build-up over time. It should be serviced/cleaned every 25-30K miles.
Old 11-08-2005, 04:05 AM   #5
sheetmagnet
sheetmagnet Normal reputation
Send a message via Yahoo to sheetmagnet
Re: Motor reving
Um... 1500 rpm-down-to-idle after you stop could also be slight miscommunication between your VSS and your ECU program... which can happen frequently, and is quite normal to happen for periods of up to 5 seconds (in certain situations during periodic braking after driving in gear, your ECU anticipates you to upshift or downshift, and will add extra fuel in anticipation for you to re-open the throttle body and engage the clutch to efficiently transfer into a higher RPM range). Spark timing and fuel curve are also modified in those cercumstances. Unless your syptoms are relatively extreme and random, don't worry too much.
sheetmagnet is offline   Reply With Quote
Old 11-08-2005, 07:00 AM   #6
fasstdak
fasstdak's Avatar
This is true...but also goes into more than the basic checks. The idle will stay above 1200rpm +/-100 until you're at a complete stop but that's regardless of being in gear or not. A dirty IAC can exaggerate this common function of the PCM and VSS.
Old 11-08-2005, 08:36 AM   #7
the_game_rock
Re: Re: Motor reving
it will drop soon as I stop but will stay reving until either I stop or put it in gear and back out
Bookmarks
Google
Web AF
