Backfire
EgonR
11-06-2005, 08:30 AM
Well I had the stock exhaust on the car. It backfired a lot. I never had this problem with any car and I never new anyone with this problem. So just to be safe I bought a new Exhaust system and did the usual tune-up (plug, wires, oil, filters). Well I still have the backfire and its really annoying. Does anyone know if this is a bad thing and if there's anyway to fix it?
Capt.Moe
11-06-2005, 11:21 PM
uhm, it's a rotary? Don't like it go back to pistons.
badassfocus1101
11-06-2005, 11:32 PM
thats not juss because its a rotary there captain.... my 7 never backfired till i took the exhaust off and was runnin strait from the down pipe.... but.. u got a cat on it? and what kinda exhaust..stock? ( the new one) and does the engine sound alright???
Capt.Moe
11-07-2005, 12:38 AM
Ohh I know, but if it's an NA it usually backfires more then a turbo:P At least that has been my experience.
EgonR
11-07-2005, 08:33 AM
well the 13b-rew's dont come NA they are all TT. And the new exhaust was an Apex N1 exhaust. The engine runs great. Only 70k miles. Been taken care of buy an old lady before I bought it. Have records of tune ups and shtuff every 3 months or so.
drftk1d
11-07-2005, 02:32 PM
backfire is caused by unburnt fuel in the exhaust
so maybe your fuel mixture is too rich.
backfire is normal on rotaries, but if its excessive, check the engine codes the ecu throws and come back
Capt.Moe
11-07-2005, 07:56 PM
You know how much Mazda wants to check the codes on my buddies car? 2 hours worth of shop time for a 3 minute job.
badassfocus1101
11-07-2005, 08:34 PM
might be a good idea to go ahead and get the codes ran like drftkid said... or get a A/F gauge (air fuel ratio)
FDTT
11-07-2005, 09:09 PM
A/F guage is practicaly useless withotu a wideband O2.
you can get a lean rich guage, but there junk too :P
drftk1d
11-08-2005, 12:51 PM
im pretty sure you can check the codes yourself
FDTT
11-08-2005, 01:45 PM
Yup you can check the err codes yourself.
86-88: http://fc3spro.com/TECH/HOWTO/ERRORCODES/ZENKI/zerror.html
89-91:http://www.1300cc.com/howto/how2/codes.html
93-96:Jump the TEN and GND pins inside the little black Diagnostics box. The box is under the hood on the drivers side, it says Diagnostics right on it. Once you do that turn the key on and watch the Check Engine light, it'll blink out the codes. Here's a list with instructions that I took from a website:
ECU Error Codes
To cause the ECU to flash the error codes on the MIL, short the TEN and GND terminals on your diagnosis connector, with the ignition off. Then turn your key to the "on" position and count the flashes.
To clear the error codes, disconnect the negative battery cable for at least 20 seconds, and depress the brake pedal. Re-connect the battery cable.
In the "pattern" column, the "L" stands for a long flash, and the "S" stands for a short flash.
Code Pattern Problem Memorized
02 SS Crank angle sensor no NE signal Yes
03 SSS Crank angle sensor no G signal Yes
05 SSSSS Knock sensor open or short circuit Yes
06 SSSSSS Speedometer sensor Yes
09 SSSSSSSSS Water Thermosensor open or short circuit Yes
11 L S Intake Air Thermosensoropen or short circuit Yes
12 L SS Full Range Throttle sensor open or short circuit Yes
13 L SSS Pressure Sensor open or short circuit Yes
14 L SSSS Atmospheric pressure sensor (in ECU)open or short circuit Yes
15 L SSSSS Oxygen Sensor less than .55v for more than 120 sec in feedback mode Yes
16 L SSSSSS EGR Switch open or short circuit Yes
17 L SSSSSSS Feedback System No change for 25 sec in feedback mode Yes
18 L SSSSSSSS Narrow Range Throttle Sensor open or short circuit Yes
20 LL Metering Oil Pump Position Sensor open or short circuit Yes
23 LL SSS Fuel Thermosensor open or short circuit Yes
25 LL SSSSS Pressure Regulator Control Solenoid open or short circuit No
26 LL SSSSSS Metering Oil Pump Stepping Motor
27 LL SSSSSSS Metering Oil Pump Sensor open or short circuit or MOP sticking Yes
28 LL SSSSSSSS EGR Solenoid open or short circuit No
30 LLL Split Air Bypass Solenoid open or short circuit No
31 LLL S Releif 1 Solenoid open or short circuit No
32 LLL SS Switching Solenoid open or short circuit No
33 LLL SSS Port Air Bypass Solenoid open or short circuit No
34 LLL SSSS Idle Speed Control Solenoid open or short circuit No
37 LLL SSSSSSS Metering Oil Pump low battery voltage Yes
38 LLL SSSSSSSS Accelerated Warmup System Solenoid open or short circuit No
39 LLL SSSSSSSSS Releif 2 Solenoid open or short circuit No
40 LLLL Purge control Solenoid open or short circuit No
42 LLLL SS Turbo Precontrol Solenoid open or short circuit No
43 LLLL SSS Wastegate control Solenoid open or short circuit No
44 LLLL SSSS Turbo control Solenoid open or short circuit No
45 LLLL SSSSS Charge control Solenoid open or short circuit No
46 LLLL SSSSSS Charge Releif Solenoid open or short circuit No
50 LLLLL Double Throttle control Solenoid open or short circuit No
51 LLLLL S Fuel Pump Relay open or short circuit No
54 LLLLL SSSS Air Pump Relay open or short circuit No
71 LLLLLLL S Front Secondary Injector open circuit No
73 LLLLLLL SSS Rear Secondary Injector open circuit No
76 LLLLLLL SSSSSS Auto Tranny Lockup Signal open or short circuit No
77 LLLLLLL SSSSSSS Auto Tranny Reduce Torque Signal
If more than one failure is present, the codes will be indicated in numerical order, lowest number first.
EgonR
11-09-2005, 07:45 AM
Well its def not that the fuel is rich. I have to use crummy 90 Octane here on base. Thats the only affordable gas i can get. Unless I wunna go offbase and pay about $160 to fill my tank. Of base is the nice gas 95 and 97 Octane.
drftk1d
11-09-2005, 09:37 AM
maybe you dont understand what "rich" means;
its when the engine gets TOO MUCH fuel at a specific time, it has nothing to do with octane rating
EgonR
11-09-2005, 01:14 PM
its when the engine gets TOO MUCH fuel at a specific time, it has nothing to do with octane ratinggotcha...idk. I guess ill check those codes. Thanks guys
