Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > Tercel
Old 11-05-2005, 05:04 PM   #1
gizzy85
gizzy85 Normal reputation
86 Tercel Carburator trouble
I am not familiar with Toyota carburators, but i have a pretty good understanding of how they work. I am having trouble adjusting my choke in order for it to run better in cold winter conditions. The first 10- 30 seconds after start up it seems to run on only 2-3 cylinders. It is not an ignition problem because i just did a complete tune up (wires plugs distributor and rotor air filter fuel fiter) Fuel pump has correct pressure of around 10 psi. I also changed my head gasket intake and exhaust gaskets because they were leaking, I timed my engine and did final adjusting on distributor. I have eliminated all possibilities other then my carb. Any advice on how to adjust my carb would be greatly appriciated.
gizzy85 is offline   Reply With Quote
Old 12-03-2005, 10:30 PM   #2
sultan_of_speed
sultan_of_speed Normal reputation
Re: 86 Tercel Carburator trouble
Hey Sounds real simaliar to my car troubles!! the float in the carb came of the pin, on one side and got twisted and was allowing to much fuel in to the engine. pull top off carb turn upside down and look at float it should have 9/32" clearance betwwen top of float and carb body. is it fouling any of the plugs??
sultan_of_speed is offline   Reply With Quote
Bookmarks
Google
Web AF
