Need some help PLEASE!
1Bad89SC
11-05-2005, 03:09 PM
My '86 720 has started to stall.
Stalled twice under load Thurs
night.Then I was cruising at 60
and it stopped running.Both times
it started back up.So I figured it
needed a fuel filter change.Changed it
yesterday.Then my wife moved it and the
it wouldn't start.Primed with gas.First
time started then stalled.Next time started
and ran.Anyone have any ideas?
Will2
11-06-2005, 07:30 AM
Starting with simple/cheap things first. Water/condensation build up in the gas tank. Even if the fuel filter is new. Water will screw it up real quick. Try a couple of bottles of dry gas.
1Bad89SC
11-06-2005, 09:19 AM
Someone suggested the fuel pump.
I've put dry gas and just recently
another additive.
billybob 711
12-29-2005, 10:07 PM
You say that you changed the fuel filter. There are 2 filters on those, one under the hood and one on the frame by the gas tank. Check your EGR and MAP sensors. Had a problem on my 82 where it would cut out - turned out to be a wire on the fenderwell had worn insulation and grounded out occasionally. Good luck!
