1994 Accord Problemse59291 11-05-2005, 02:48 PM My speedometer, tachometer,temp gauge, rear defroster and windows stopped working. I also have to put key in tranny unlock to take out of gear. Any help? Igovert500 11-05-2005, 04:24 PM Are you getting any Check Engine lights or blinking lights on your dash or near your shifter? Also check your fuses. e59291 11-05-2005, 04:43 PM Are you getting any Check Engine lights or blinking lights on your dash or near your shifter? Also check your fuses. No check engine light codes. Nothing comes on except for battery sign when I start vehicle. Have to manually unlock tranny but car starts and runs. e59291 11-05-2005, 04:45 PM No check engine light codes. Nothing comes on except for battery sign when I start vehicle. Have to manually unlock tranny but car starts and runs. Also fuses for windows are dead but not all. mpumas 11-05-2005, 05:03 PM Check all the fuses. Problem may be with fuse that powers integrated control unit. Fuse should be on left kick panel inside car on driver side. jeffcoslacker 11-05-2005, 09:49 PM It sounds like you've lost or shorted out a whole power feed primary on the ignition side, After checking your fuses, pay close attention to any primary power feed wiring near the battery and the main power distribution box under the hood. It could be anywhere from there all the way to the ignition switch. Check any connectors under the dash or coming from the steering column that could be involved also. Automotive Network, Inc., Copyright ©2012
