Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > 4Runner/GX470
Old 11-05-2005, 11:25 AM   #1
gunnyb
gunnyb Normal reputation
Angry Running hot
I have a 1995 4Runner that keeps running hot. I've replaced the Radiator and Thermostat but it keeps running hot. There is no leaking when it has been sitting still. I can fill the radiator up prior to driving and still it will run hot. What could be the problem? Water pump? I' lost.
gunnyb is offline   Reply With Quote
Old 11-05-2005, 01:52 PM   #2
4Wheel
AF - Advisor
4Wheel's Avatar
4Wheel Normal reputation
Re: Running hot
Need more information.
What engine? 4cvl V6
Like are you "using" coolant (consumming)?
Does the engine run smooth?
Any other symtoms?
4Wheel is offline   Reply With Quote
Old 11-05-2005, 02:53 PM   #3
Brian R.
Resident Chemist
Brian R.'s Avatar
Brian R. Normal reputation
Send a message via Yahoo to Brian R.
Re: Running hot
Welcome to the AF!
Yes, it could be your water pump is corroded and not pumping well.
Could also be your radiator. See if some spots are alot cooler than others, indicating a stopped up portion of the core.
Could be the fan clutch has lost it's oil and your fan is not turning fast enough if the engine stays at normal temp when you are moving on the road, but not when you're stopped or moving really slow.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Brian R. is offline   Reply With Quote
Old 11-05-2005, 07:22 PM   #4
gunnyb
Re: Re: Running hot
I'm using 50/50 coolant. V6 engine. It runs good until it heats up.
Any other symtoms?
Old 11-05-2005, 07:26 PM   #5
gunnyb
Re: Re: Running hot
From what you've told me, I think it is the water pump. Because once this thing gets hot, it dosen't matter if it's standing still or moving the temp guage stays on H
Originally Posted by Brian R.
Welcome to the AF!
Old 11-05-2005, 08:21 PM   #6
Brian R.
Resident Chemist
Brian R.'s Avatar
Re: Running hot
Could also be a head gasket, but the water pump is definitely the first thing to try. Don't forget to check the radiator for blockage. I guess it's not likely to be the radiator, but it's a test you can do without any work or time other than heating the engine up.
It could also be the suction radiator hose (bottom) is collapsing internally and not letting coolant be sucked by the water pump.
Old 11-10-2005, 08:15 AM   #7
SidneyCanada
SidneyCanada Normal reputation
If it's a V6 then there is a recall on it.
24 Toyota headgasket & oil sludge recall sites:
http://www.brian894x4.com/V6headgasketrecall.html
http://home.off-road.com/~kemanuel/V6-HG.htm
http://www.showmesome.info/hilux/info/recall.htm
http://www.off-road.com/toyota/4runner/topqs.html
http://www.yotatech.com/~corey/4runner_faq.htm
http://www.thecomplaintstation.com/c...inalrecord=14/
http://www.babcox.com/editorial/ic/ic110028.htm
http://www.alldata.com/recall/make/Toyota_Truck.html
http://www.alldata.com/TSB/60/94601650.html
http://www.yotarepair.com/Campaigns.htm(3.4L,V6,headgasket recall)
http://home.off-road.com/~bibelheime...eadgasket.html (3.4L,V6,headgasket recall)
http://home.4x4wire.com/erik/t100/3.4v6_headgasket.htm
http://www.jasperengines.com/pdf/5SFECoolantLeaksTB.pdf
http://www.lemonaidcars.com/secret_warranties.htm
http://www.nordicgroup.us/oil.htm#Toyota%20Sludge
http://www.toyota.com/about/news/pro...-consumer.html
http://www.usatoday.com/money/autos/...ota-sludge.htm
http://www.apa.ca/template.asp?DocID=23
http://www.petitiononline.com/TMC2003/petition.html
http://www.nhtsa.dot.gov/TSBScans/sb621323.pdf
http://www.nhtsa.dot.gov/TSBScans/sb628694.pdf
http://groups.msn.com/ToyotaOwnersUn...gaskettsb.msnw
http://groups.msn.com/ToyotaOwnersUn...adgaskets.msnw
http://www.babcox.com/editorial/ic/ic100052.htm
Sidney® ™
Repairs tv's,vcr's,home/car audio out of my home
E-mail:sidneybek@yahoo.com
Dartmouth,Nova Scotia
Canada
1985 Toyota 4-Runner,solid front straight axle,factory cruise control,sunroof,22R-E,W56,RN60LV-MSEK,rusted rear step/towing chrome bumper with 246 000 KM
SidneyCanada is offline   Reply With Quote
Old 11-10-2005, 04:14 PM   #8
4Wheel
AF - Advisor
4Wheel's Avatar
Re: Running hot
Sidney STOP telling people there is a "RECALL" there was never formally a recall Toyota referenced it as a service campaign and it ended years ago and even then then it was not a SURE thing you would get the work paid for!!!!
Old 11-10-2005, 04:52 PM   #9
SidneyCanada
Re: Re: Running hot
The government in Canada & USA will force car manufacturers to recall a vehicle based on safety or emissions but the headgasket was a voluntary recall made by Toyota as many notices were mailed to customers and many customers were notified by phone.As well many owners would contact any Toyota dealership or even the head office and give them the VIN afterwards the owner would take their truck to any Toyota dealership and have the work done at no cost to them and given a free rental car.
Some people who already had the work done elsewhere would partially or completely get re-embursed by Toyota,I have read this many times on the 61 or so 4-Runner/pickup dedicated discussion sites.
ARE YOU FEELING HIGHLY TERRITORIAL? OR LOOSING A POWER
GRIP/TRIP?.
Here are the sites for you:
Here are 39 other 4-Runner/pickup discussion sites which have free classifieds:
http://www.wildyoats.com/vbulletin
http://www.yotatech.com/index.php
http://www.toyota-4runner.org
http://www.toyotaoffroad.com
http://mkelly.proboards22.com
http://www.t4x4pickup.com/dgroup/index.html
http://www.voy.com/83795/
http://www.4x4wire.com/toyota
http://forum.ih8mud.com
http://board.marlincrawler.com/index...0db2fa424afcf&
http://www.birfield.com/modules.php?name=Forums
http://www.pavement s u c k s.com/forums/viewforum.php?forum=14
http://www.automotiveforums.com/vbul...splay.php?f=65
http://www.automotiveforums.com/vbul...lay.php?f=1146
http://www.toyotanation.com/forum/f22
http://www.4wheelparts.com/forum/default.asp
http://www.pirate4x4.com/forum/forumdisplay.php?f=12
http://mtt.truckmoxie.com/forums
http://toyotatruckworld.tenmagazines.com/forums
http://4roc.org/forums/index.php
http://www.4x4review.com/discussions/toyota
http://members.boardhost.com/wildrice/
http://www.gator4x4.com/forum/viewforum.php?f=5
http://www.b2g5.com/boards/board.cgi?user=marktoyota
http://www.toyotaownersclub.com/forums/index.php?
http://www.suvfans.com/forums
http://www.network54.com/Hide/Forum/11128
http://www.toyota-parts.com/bb
http://www.toyotaboard.com
http://www.toyotaworld.com/bbs
http://forums.vmag.com
http://groups.google.com/groups?grou....toyota.trucks
http://www.talkaboutautos.com/group/....toyota.trucks
http://groups-beta.google.com/group/....toyota.trucks
http://news-reader.org/alt.autos.toyota.trucks/
http://www.totally-toyota.com/toyota...cks/index.html
http://www.autoforumz.com/Toyota-forum-65.html
http://autos.groups.yahoo.com/group/toyota4runners
http://autos.groups.yahoo.com/group/toyota4runner/
http://autos.groups.yahoo.com/group/the4runner4x4club/
http://autos.groups.yahoo.com/group/4-runner/
http://autos.groups.yahoo.com/group/4runner/
http://autos.groups.yahoo.com/group/wills4runnerworld/
http://lists.off-road.com/mailman/listinfo/toy4x4
http://ar.groups.yahoo.com/group/ClubDaihatsu4x4
These are 6 Canadian based 4-Runner/pickup sites which have free classifieds:
http://www.toyotaoffroad.ca/forum
http://www.toontoysforums.ca
http://www.4wheeler.ca
http://www.bogginfreaks.com
http://www.bc4x4.com
http://island4x4.com
These are 11 Toyota DIESEL 4-Runner/pickup sites which have free classifieds:
http://www.sr5.net/bbs/index.sht
http://www.toyotadiesel.com/phpBB2
http://autos.groups.yahoo.com/group/toyotadieselclub
http://pub12.ezboard.com/btoyotasurfdownunder
http://www.toyotasurf.asn.au/forum
http://groups.msn.com/toyotasurf/shoebox.msnw
http://www.yotasurf.com/forums/index.php?
http://www.yotasurf.co.uk/forums/index.php
http://www.offroadpakistan.com/forum...forum.php?id=8
http://clean4x4.com/
http://jplan.com/cgi-bin/tractor/for...ickup%20Trucks
http://www.biodieselsolutions.ca/
These are Turbo gas based 4-Runner/pickup discussion sites which have free classifieds:
http://autos.groups.yahoo.com/group/22RTE-Trucks
http://www.well.com/user/mosk/welcome.htm
http://www.turboparts.info/pages/620208/index.htm
These are 2 Trekker based discussion sites:
http://groups.yahoo.com/group/toytrekkers
http://www.toyotaoffroad.com/Article...er/Trekker.htm
Sidney® ™
Canada
Old 11-11-2005, 01:09 PM   #10
4Wheel
AF - Advisor
4Wheel's Avatar
Re: Running hot
Yes and your links, the ones that arn't broken say that is has been over for years!
Please people are here to get answers to specific questions and respect those that respond, and TRUST you when you post so respect their trust and post responsibly, check your facts.
Thanks for all the links and links and links......
Bookmarks
Google
Web AF
