stripped screwsrps13freak 11-04-2005, 04:03 PM how would i go about getting stripped screws out D-Bo 11-04-2005, 04:05 PM out of what? i'd say yank em and re thread the hole afterwards Broke_as_**** 11-04-2005, 04:41 PM Depends on what the screw is in. If it's just a plastic piece then by all means rip, pound or otherwise force it out and put another larger screw in. If the screw is something you really don't want to screw up like a screw going into an aluminum head then I suggest trying to file down a pair of flat sides into it and try using a wrench to pull it out. Worse case senario go down to your local autoparts store and get a cheap striped puller kit and do it properly. nissanfanatic 11-05-2005, 01:12 AM What screw? D-Bo 11-05-2005, 08:59 PM out of what? Depends on what the screw is in. What screw? thats the main question. where is it? what would the consequences be if you pulled it/filed the sides/used the puller kit? mynismo 11-06-2005, 01:52 PM this is one of the lamest threads i've ever seen rps13freak 11-07-2005, 08:04 PM its on my headlamps. there the screws holding in the metal clamp that holds the headlight. D-Bo 11-07-2005, 08:24 PM ther are a few screws holding the headlights.. and yes, it is a lame thread mynismo 11-10-2005, 08:31 AM i took a torch to it. seriously. Automotive Network, Inc., Copyright ©2012
