96 200sx stuck in 2nd gear????h22hatch91 11-04-2005, 03:03 PM i have a friend who has got a 200sx and she said she was driving it and when she tryed to take it out of second gear and put it in third it wouldnt come out, so its stuck in second and wont go into any other gears not even neutral (its a 5 spd) anyone know what the problem is???? ...............thanks for the help fugiot 11-04-2005, 03:13 PM wow, does it still move in 2nd? Can you drive in 2nd gear? If so, it's probably just the linkage components that are screwed up somehow. Taking it somewhere to be fixed shouldn't be too bad if the problem's not actually IN the tranny. h22hatch91 11-04-2005, 06:59 PM yeah it still will go in 2nd gear ......so that mean its the shift linkage??? fugiot 11-05-2005, 05:30 AM I think so. I can't think of anything that could go wrong from within the tranny to make that happen. It must be the actual shifter itself not working properly somehow. h22hatch91 11-05-2005, 09:22 AM i talked to her and she said there was fluid on the ground..........that means she leakin clutch fluid right??? idk i just need to look at it first.....shes not giving me any detail soo i will go check it out and let u know what i see.......thanks LucinoSR20 11-05-2005, 01:40 PM i talked to her and she said there was fluid on the ground..........that means she leakin clutch fluid right??? idk i just need to look at it first.....shes not giving me any detail soo i will go check it out and let u know what i see.......thanks eew, fluids never good, when theres not supposed to be. What color is the fluid? Is the clutch hydrualic, if not then the fluid might be coming straight out of the tranny. No good man, tell her to stop reaming it into th egears lol, jk, i hate working on tranny/clutch/shift crap. GL fugiot 11-05-2005, 06:37 PM OOOOH, it could be clutch fluid(not sure what year Sentras starting coming with hydro-clutches. But if it is, it might mean that you can't disengage the clutch to change gears. If it's clutch fluid, it should be cheaper to fix than a shifter linkage anyway. slideways... 11-05-2005, 11:08 PM it could be water from the A/C, or fluid from the turn signal LucinoSR20 11-14-2005, 12:00 PM always with the turn signal fluid slidey.... get yer head checked! or stop drinking one of the two. slideways... 11-18-2005, 04:50 AM stop drinking ...but i like my alcohol :smokin: Automotive Network, Inc., Copyright ©2012
