TD27 engine
diverdog
11-04-2005, 07:09 AM
Does anybody know how many HP has the td27 engine?
Brewmaster
01-11-2006, 01:05 PM
First of all you must remember that Horsepower doesn't really matter unless you plan on seeing how fast your vehicle can go. This applies to petrol, diesel, electric whatever propels you down the road. The numbers that decide how quickly you get to that speed are foot pounds of torque. Torque is the thing that pushes you back in your seat. When you push the gas pedal to the floor and your vehicle takes off - that's torque. Horsepower is what takes you into the triple digits with the RPM maxing out. (not really but that's the easiest way to explain it) In most gasoline (petrol) powered machines the numbers are pretty much square meaning they match. In diesel, however, the torque is almost always much higher than the horsepower. So the 2.7 is rated as having 99 HP but performs the same as a gasoline engine rated with 160 HP.
Here endeth today's lesson. :-)
Nissan Terrano specs:
_____________________________
Engine 2,663cc TD27T
Horse Power (hp/rpm) 99/4000
Torque (lb-ft/rpm) 159/2200
Gas Tank (l) 80
Top Mileage (km/l) (AT/MT) 16.5/17.5
Weight (kg) (AT/MT) 1790/1770
Length*Width*Height (cm) 436*169*168
jimbo3172
06-07-2007, 01:46 PM
Hi guys, just joined and can't work out how to start a new thread. Can anyone point me in the right direction?
Thanks
