Accord doesn't have power left
crpederson
11-04-2005, 01:07 AM
Hi,
Yesterday i was driving into my steep driveway and my 1993 Accord EX couldn't make it up the driveway. This seemed out of nowhere. I parked it and tried the next day only to find I couldn't pull it out of park (Its an automatic). So I keyed the shift lock and that seemed to work to get it out of park. I drove it around the block up some hills and it is severely lacking in acceleration. We checked the transmission fluid and it was fine.Something is definitely wrong here. Also, i noticed a peculiar smell coming from somewhere (kind of like a burning). Thanks in advance.
mpumas
11-04-2005, 01:38 AM
Lets me try to understand. Does it feel like the transmission is slipping. Engine speed increases but the car doesn't want to move?
crpederson
11-04-2005, 02:58 AM
Pretty much. When i put the pedal down to accel the car doesn't do much.
mpumas
11-04-2005, 01:54 PM
If you move the shift lever slightly either way . does it make a difference. If it does, the cable adjustment may be necessary. Otherwise, you may need a new transmission.
mpumas
mpumas
mpumas
11-04-2005, 01:55 PM
russiankid
11-04-2005, 04:24 PM
the burning smell could be that your clutch is worn out and is slipping causing the shoes to melt a bit
crpederson
11-04-2005, 05:03 PM
this car is an automatic, thanks
crpederson
11-04-2005, 05:05 PM
how much are new transmissions?
-thanks
russiankid
11-04-2005, 11:00 PM
this car is an automatic, thanksok and your point is? it still has a clutch which in your case sounds like its worn out
mpumas
11-04-2005, 11:14 PM
Russiankid--automatics have clutches? Not really, they have a torque converter and internal bands. But not clutches per se.
AccordCodger
11-05-2005, 09:23 AM
I STILL say you have a lot to learn, young man.
bjd088
11-05-2005, 11:34 AM
In answer to the question, transmissions are expensive, I hope for your sake it is just an adjustment.
AccordCodger
11-05-2005, 01:09 PM
Expensive as in more than the book value of the car (AFTER it's fixed). There's always the solution of a used transmission if you want to go that route.
You didn't answer the question as to whether the RPMs go up without the car accelerating. That's a key piece of information, and readily available by looking at the rev counter while you're driving. Having said that, the burning smell, while possibly unrelated, is not a good sign. But there ARE other possibilities, depending on your answer.
How long have you had the car? How many mies on it? Do you know its history? How has it been driven?
