cooling fans`micali 11-04-2005, 12:30 AM Has anyone repalced the cooling fans on their Impala? One of mine finally quite because of the temp switch going out. Is it hard? billyo69 11-04-2005, 05:51 PM I have had mine replaced twice.The second time i bought it online and it was cheap and they were good quality.Its a bit of a pain in the ass job. bermis519 11-04-2005, 10:18 PM why would you replace the cooling fan if the temp sensor is bad...replace the temp sensor first to see if that will fix the problem with the cooling fan...and I would recommend turning the air conditioning on when testing the fans.....just makes them come on quicker... mike micali 11-04-2005, 10:34 PM The bearings were going out in the fans for a while and one fan finally quit. The fan for the ac works but thats it. Where did you find them at? billyo69 11-05-2005, 05:38 PM why would you replace the cooling fan if the temp sensor is bad... My passenger side fan burnt out twice from running constant due to bad whatever causing them to run. bermis519 11-05-2005, 07:38 PM I got my temp sensor from napa....8.76 mike Automotive Network, Inc., Copyright ©2012
