faster car
civicex96
11-03-2005, 11:17 AM
Honda Civic EX 96'
if you were given a honda civic ex 96' stock. what would be the first thing you did to it to make it have more RPMs and make it go faster.
Ace$nyper
11-03-2005, 11:22 AM
Honestly just sell it.
I would search and read up on the b18c1 swap.
SiGNAL748
11-03-2005, 11:38 AM
h22a
Ace$nyper
11-03-2005, 11:41 AM
h22a
DOOD WTF IS WRONG WITH YOUR SIG
thats fucked up
Schister66
11-03-2005, 11:45 AM
K20.......want one???
QUICK_EG_B16A
11-03-2005, 02:02 PM
That's a broad question. I think the most cost effective thing would be to do a swap. Then modify that engine. Don't waste the money modding a d series.
Schister66
11-03-2005, 03:05 PM
d series does have potential though......w/ bottom end modification and BOOST
civicex96
11-09-2005, 01:25 PM
my honda civic ex 96' is lowered with a k&N short ram intake on it
how much would it be to swap the engine and what type of engine should i get and im saying i want a fast car.
CivicSpoon
11-09-2005, 01:32 PM
If you want a fast car, you'll have to do more than just an engine swap. An engine swap, build the engine, and turbo would be your best bet. Otherwise a K20 would be your best bet (then h22a, then ITR, then GS-R, etc). The cost will completely depend on what engine you go with and what you do to it. Figure out a budget (a real budget, none of that "well I think I might be able to spend $10K" crap), and figure out some reasonable power goals (400whp isn't going to happen for $5K).
Schister66
11-09-2005, 02:31 PM
just know that w/e you pick, power doesn't come cheap and there are no ways around spneding a good chunk of change. Your best bet is to swap and boost if you're not happy w/ the power that the new engine has. A b18c1 swap and boost is going to cost $6-7k+ for a good engine and a turbo set up....and that's on a stock engine.
As soon as you know what you what and the budget you have, then we'll talk
civicex96
11-11-2005, 10:43 AM
ight well i got around 2000 and i dont want to do an engine swap rite now what modifications should i buy to gain hp or what would be my best option.
Schister66
11-11-2005, 12:52 PM
Greddy turbo kit would be the best bang for the buck as far as factory mods....you could build a DIY turbo kit and see some pretty big hp gains...
iVteC_PoWeR
11-15-2005, 08:51 PM
since your on that low of a budget save some more money strengthen your internals and turbo...
Schister66
11-15-2005, 11:43 PM
on a D, you can make up to 220whp before needing to worry about internal mods.....get the Greddy or a DIY turbo kit and you'll be good and you won't break the bank.
duffman868
12-02-2005, 12:40 AM
just use spray and when you blow the d just drop another and keep spraying
CivicSpoon
12-02-2005, 12:49 AM
And then sooner or later you'll have spent enough $ that could have gone towards a turbo kit.
Kuntry_Boi06
12-02-2005, 11:53 AM
do what schister said turbo the damn thing it is a lot cheaper than a engine swap and you can gain huge power from it. plus it's cheaper.
Schister66
12-02-2005, 12:39 PM
See everyone agrees...im' always right!! :p
check out www.turbod16.com www.homemadeturbo.com and www.honda-tech.com
you should be able to get all fo the info you need from those sites and AF.....turbo D16 is going to have the most info for you!!
93civicsiracer
04-27-2006, 06:15 AM
to answer the original question. for more rpm. chip the ecu witha skunk 2 program. d series engines have a lot a potential. who ever says they dont smokes crack. i had a d series running at 31/2 cylinders, (3 of 4 said about 100 psi and 1 said 50psi. ) and i was smokin people left and right. if u get an old engine and bring it back to stock specs before building on it ull get a lot better results with ur car.thats what iv done with all my engines
