Having gauge problems? heres the answermaltesesteeze 11-02-2005, 02:32 PM To all you 1997-2001 cherokee owners having that annoying problem of intermminent gauge dropouts and airbag light illumination, heres what is happening. It is a bad wiring harness that has notoriously gone bad over a relatively small time period. So bad that Jeep has recognized it and will be able to fix it easily. Unfortunately its not a bad enough problem that they make a recall so its not a free repair unless youre still on warranty. If you really wish to get it fixed, you have two options: You can pay the dealer to fix it up, which costs $104.00. Or you can buy the needed parts for $20.00 and try and do it yourself. I'll probably do it myself, and ill let you all know how easy or difficult it actually is. Hope this helps everyone, I've had the problem for while and this is the only real answer anyone has ever given me. Best of Luck! AlohaBra 11-03-2005, 12:42 PM What are the parts that you need and where can I order them. Is it the airbag recall...I had that done. maltesesteeze 11-03-2005, 03:23 PM As i said, its not a recall. The part number is 05106261aa. I tried going in there and looking at it but its more than i want to deal with, I'm mechanically inclined but this requires a little additional saldering skills. I did however clean the connectors between the harnesses and the back of the gauge and its fixed for now, but who knows when it may start again. Good luck refrigerationdude 11-04-2005, 03:11 AM As i said, its not a recall. The part number is 05106261aa. I tried going in there and looking at it but its more than i want to deal with, I'm mechanically inclined but this requires a little additional saldering skills. I did however clean the connectors between the harnesses and the back of the gauge and its fixed for now, but who knows when it may start again. Good luck So this is whats causing my gas gauge problem? I'm gussing more and more of my gauges are going to start acting up? I have a 98 Cherokee sport. Could you post more info as to what is bad, is it the wiring harness itself, or the connectors, a relay, etc?? Where did you clean, at the gauge cluster or the otehr end of the harness, which is where? Thanks, Jeff maltesesteeze 11-04-2005, 03:32 AM if you want every small detail call a jeep dealership, tell them the symptoms and they'll explain it. But they will probably try and use unnecessary language to confuse you. It is faulty wires in what I believe is the wiring harnesses that plug into the back of the gauge cluster and go to the ecu. Its not fun getting all that dash stuff off, but just pull where there arent any obvious screws and it'll pop out. I cleaned the plug recievers on the back of the cluster (there are two identical, rectangular white plug areas) and the two plugs from the wiring harness and just put it back in with as solid a connection as i could get. Its been two days now and its had zero problems so im keeping my fingers crossed. Like I said, give that a shot and if youre lucky it'll help. Otherwise the part is $8.20, $20 for parts from the dealer with things like heat tube and soldering wire, and around $100 for labor if you really want to bend over and have it repaired. AlohaBra 11-06-2005, 01:36 AM So this is whats causing my gas gauge problem? I'm gussing more and more of my gauges are going to start acting up? I have a 98 Cherokee sport. Could you post more info as to what is bad, is it the wiring harness itself, or the connectors, a relay, etc?? Where did you clean, at the gauge cluster or the otehr end of the harness, which is where? Thanks, Jeff[/QUOTE] ************************************************** ** The gas gage problem is a recall on the 97, maybe the 98, because it would run out of gas before it showed empty...mine ran out twice. They change the sender in the tank. This erratic gage issue has not happened on my 97 XJ Sport. fredjacksonsan 11-09-2005, 10:32 AM Lots of folks have this same problem; good post. 95xjsport 11-09-2005, 03:35 PM good post... My 98 is doing that, so basically, I should take the cluster and clean out the connectors? but why does it "fix itself" when I flip the wipers on and off? My friends "fixes itself" when he flips the headlights on and off... fredjacksonsan 11-09-2005, 03:52 PM Electronics are funky...my wife's 99 did the same thing. Maybe the voltage change when changing wipers/lights is enough to do it. 95xjsport 11-09-2005, 04:05 PM Thats true, The lighs and wipers probably do draw a substancial a bit of power DOCTORBILL 07-23-2011, 11:42 AM The electrical connectors have thin metal slivers that slide into thin metal sockets. They get oxidized and the connection can be disrupted. Our air now has oxidizing pollutants that can form an oxide layer on cheaply made socket contacts. That's why the military uses gold plated contacts - at least used to.... By moving them around or scraping the male and/or female connector surfaces, you 'might' fix the problem. Oxidized contacts can 'spark' at the poor contact (high resistance) which causes even more oxidation leading to subsequent failure. Then the contacts need scraping. My deceased father was Chief electrical engineer at Hallicrafters Radio in Chicago and he used to put a thin layer of Zinc Oxide Ointment on electrical contacts and plug prongs to keep good electrical contact - it lubes the connectors and prevents oxidation. I've been doing that for 40 years, and it sure helps keep contacts good ! BTW - That's the Zinc Oxide Ointment sold in drug stores in a squeeze tube - really cheap ! DoctorBill Automotive Network, Inc., Copyright ©2012
