Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Dodge > Neon/Plymouth Neon > 1st Gen 95-99
Old 11-01-2005, 10:08 PM   #1
benderz
benderz Normal reputation
Unhappy 96 Neon sohc intermittant no start
my daughters 96 Neon was blowing fuel pump fuse ocassionally and now it doesn't want to start every time. It will crank no problem but there doesnt seem to be any fuel pressure. You can't hear the pump with the key on when this happens. Usually after 2 or 3 try's it does start up and run fine, but it does take a few minutes. Damp or humid days seem to be worse. Is there any known problems with the fuse box under the hood that could cause this? Also the horn fuse blows constantly . I have changed the horn and the relay with no luck.
I think there may be a short in the fuse box. Any help would be appreciated.
benderz is offline   Reply With Quote
Old 11-02-2005, 08:29 AM   #2
das2123
Tuning Neons since '97
das2123's Avatar
das2123 Normal reputation
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: 96 Neon sohc intermittant no start
Check your grounds or for loose/exposed wires. Fuses continuing to blow, usually indicates a bad ground or faulty wiring. Check the wiring under the battery box. Sometimes battery acid will leak out and corrode the wires.
das2123 is offline   Reply With Quote
Bookmarks
Google
Web AF
