1999 4runner starter problemswk121 11-01-2005, 09:42 PM I have a 4cyl 2.7 with 95,000miles last week it wouldnt start. no noise no nothing. Battery is good all power is working. I had it towed and the mechanic said it needs a new starter. Okay put new (rebuild) starter in. everything is good for one week. Tonight go to start the thing and nothing again. Any ideas? I find it hard to believe that the starter is the problem now. Brian R. 11-01-2005, 11:38 PM Check the starter relay. One opposing pair of contacts should show continuity. The other pair should not. If you apply battery voltage to the pair with continuity, then the other pair should then show continuity until the voltage is removed. Could still be the starter. Wouldn't be the first time a bad starter was sold as rebuilt. If the starter is the problem, it is probably the solenoid contacts that need to be replaced. http://www.automotiveforums.com/vbulletin/showthread.php?t=166530 swk121 11-02-2005, 10:27 AM Got the truck towed back to the machanic last night. He called me this morning and said it started right up first try. I will ask him to chech the starter relay. Thanks swk121 11-02-2005, 10:45 AM Just found out that when the starter was hot it wouldnt start. Getting new (Rebuild) starter put in now. Hoplfully this will be the end of it. Brian R. 11-02-2005, 06:57 PM FYI - Replacing the contacts usually solves a no-starting problem when the starter is hot. The contacts work better when cold. SidneyCanada 11-10-2005, 08:06 AM 15 Toyota (NipponDenso now called Denso) starter repair sites: http://www.off-road.com/4x4web/toyota/tech/starter/ - http://www.4crawler.com/4x4/CheapTricks/Starter.shtml http://char.tuiasi.ro/vw/reality/rogerb/4x4/CheapTricks/Starter.html http://yotarepair.com/startercontacts.html http://www.toyotaoffroad.net/afertig/88/starterrepair.htm http://www.4x4wire.com/toyota/maintenance/starter/ http://www.yotatech.com/~corey/tech/haveblue_starter/haveblue.htm http://www.sleeoffroad.com/technical/tz_starter_rebuild.htm http://www.startercontacts.com/install.htm http://www.startercontacts.com/images/OSGR%20Exploded%20view.jpg http://www.colorado4x4.net/tech/starter_contacts/starter_contacts.html http://www.barneymc.com/toy_root/techneek/starter.htm http://perso.wanadoo.fr/adherence.4x4/start_bj.htm http://www.automotiveforums.com/vbulletin/showthread.php?t=166530 http://www.toyotanation.com/forum/showthread.php?threadid=27312&forumid=10 http://www.toyotanation.com/showthread.php?threadid=27312&forumid=10 Starter contact kits (8mm ID hole): Ace Electric # S-5263 (only two contacts) Ace Electric # S-5264 (only two contacts) Metro # 66-82104 (only two contacts) (www.metroautoinc.com ,Pomona,California) Toyota # 28226-72010/80 (battery side)(also1KZTE-2LT-1KZT) Toyota # 28226-72080 (8808-9108) Toyota # 28226-16130 (9108-9308) Toyota # 28226-55050 (9308-9511) Toyota # 28226-70040 (9308-9511) Toyota # 28226-72040 (motor side if needed) Toyota # 28226-72010 (8808-9511) Toyota # 28226-74070 (9108-9511) For others besides 22R series: Toyota # 28226-54220 (motor side) (2LTE, 3L..LN13# IKZTE, 2L#, KZN130,LN108,112,85..4FC) Toyota # 28226-54250 (Diesel Surf 2.4TD, contains a new end cover and gasket) Toyota # 28226-54320 (battery side) (2LTE, 3L..LN13# IKZTE, 2L#, KZN130, LN108,112,85..4FC,3B-1HZ-BJ73-HZJ7#-1KZT-KZJ70) Toyota # 28226-17030 (battery side) (1H#-HDJ80-HZJ80) Toyota # 28226-56250 (battery side) (3B-1HZ-1PZ-PZJ7#) Starter contacts only (8mm ID hole): Ace Electric # S-5231 Ace Electric # S-5293 (crescent moon shape) Ace Electric # S-5295 (crescent moon shape) Metro # 66-82106 (www.metroautoinc.com ,Pomona,California) Tons more at: http://www.metroautoinc.com/PDF%20File/66-Denso%20Solenoid%20Contact.pdf Toyota # 28226-70040 Wilson’s Electric # 45-29-652 Starter brushes: AC Delco # D762 GP Sorensen # 255048 Standard # JX-117 Whether your starter uses two rectangular types or one rectangular and one crescent you can substitute with two squares or one square and one crescent so any of the above part #'s for those kits will be the right ones,or about half of the auto electric shops in your local yellow pages would sell aftermarket contacts for only $5 each or the pair. If the brake and charge lights come on during revving of the engine then it's a sign that the carbon alternator brushes require replacing as this is the mileage for them to wear out. In alternators the brushes wear out on average every 140-170 000 miles where on the dashboard the brake & charge light both come on at the same time. About half of the auto electric shops in your local yellow pages sell carbon alternator brushes and copper solenoid starter contacts for about $5/pair.Another way to verify that the alternator is not charging is while the engine is running bring a metal screwdriver or any metal object near the alternator and if the alternator is working properly then it should act like a magnet and grab the screwdriver. For carbon brushes R&R: http://www.4x4wire.com/toyota/maintenance/alternator_brushes/ http://www.toyotaoffroad.net/afertig/88/alternatorbrushes.htm http://perso.wanadoo.fr/adherence.4x4/alternateur_kzj.htm http://www.automotiveforums.com/vbulletin/showthread.php?t=166525 http://www.toyotanation.com/forum/showthread.php?threadid=27270&forumid=10 http://www.pirate4x4.com/forum/showthread.php?s=&threadid=26734&highlight=alternator+brush+holder http://www.bitwalla.com/cruisers/articles/alternator.html http://www.barneymc.com/toy_root/techtalk/electric/altrnatr.htm For decoding the dashboard lights: http://www.powerbase-auto.co.uk/alternator_faults.htm http://members.1stconnect.com/anozira/SiteTops/energy/Alternator/alternator.htm Here are part #'s for Toyota alternator carbon brushes and copper solenoid starter contacts which are used in about 95% of all Toyota vehicles. Toyota alternator Brushes with holder: Toyota # 27370-35060=$29 CDN Honda # 31105-PZ1-003 Metro # 39-82003 (www.metroautoinc.com ,Pomona,California) Unknown brand name # F4019-53035 Alternator brush only (qty:1 brush unless otherwise stated): AC Delco # E724 AC Delco # E731 (side wire and concave tip) Ace Electric # DA-61 (brush only),S-5367 (brush holder) Beck Arnley # 178-1669 (side wire and concave tip) Beck Arnley # 178-1376 Borg Warner # X580 (side wire and concave tip) Canadian Tire # 19-2050-6=$4.49/pair Daihatsu # 27370-87302-000 Daihatsu # 27371-63020-000 Daihatsu # 27371-87501-000 Daihatsu # 27371-70300-000 Echlin # E601=$8.16 CDN/pair (UAP/NAPA) Echlin # ECHE601 Echlin # EC480 Echlin # ECHE480 GP Sorensen # 255047 (side wire and concave tip) GM # 94123056 GM # 96054118 Honda # 31144-PD1-004=$9.72 Honda # 31144-PD1-0040 Honda # 31144-PD1-0030 Honda # 31150-PR7-A01 Honda # 31150-PTO-003 Hino Industries # 021660-0390 Hino Industries # 021660-0510 Isuzu # 8-94123-056-0 Isuzu # 8-97032-308-0 Isuzu # 8-97032-310-0 Mazda # 021660-0390 Mazda # 021660-0510 Mazda # KL47-18-W75 Metro # 38-82001(side wire concave tip) (www.metroautoinc.com ,Pomona,California) Mileage Plus # E601SB Mitsubishi # MD604474 Mitsubishi # 21660-0510 Niehoff # WA571 (side wire and concave tip) NipponDenso # 021660-0390 NipponDenso # 021660-0510 Standard # JX-116 (side wire and concave tip) Subaru # 021660-0390 Subaru # 021660-0510 Suzuki # 31631-82610 Suzuki # 31656-82611 Suzuki # 021660-0510 Toyota # 27370-42010 Toyota # 27370-75060 Toyota # 27371-63020=$5.80 (up to 9105) (side wire and concave tip) Toyota # 27371-70300=$5.20 (9105-9511) Toyota # 27371-76004-71 UAP/NAPA # MPEE601SB Victory Lap # FAX57=$4.49 CDN/pair (Canadian Tire) Wilson's Electric # 26-29-7534 (side wire and concave tip)=$2.20 each CDN (Diesel Auto Electric)(Parts for Trucks,box of 10 for $3.40 CDN) Specifications: Length=15 mm Width=7 mm Thickness=5 mm Lead length=49 mm These Honda alternators are the same except the pulley must be swapped: 1986-89 Honda Accord (Carb),the EFI can be used but the voltage reg must be swapped 1990-93 Acura Integra Sidney® ™ Repairs tv's,vcr's,home/car audio out of my home E-mail:sidneybek@yahoo.com Dartmouth,Nova Scotia Canada 1985 Toyota 4-Runner,solid front straight axle,factory cruise control,sunroof,22R-E,W56,RN60LV-MSEK,rusted rear step/towing chrome bumper with 246 000 KM O |\ __O _|_| \ (\__/) (='.'=) (")_(") This is Bunny.Copy and paste bunny into your signature to help him gain world domination vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
