How to remove right rear lens housing to change light bul
bumsinflt
10-31-2005, 08:52 PM
Right rear tail light burnt out - how do you remove the bulb to replace - is it the lens that's taken off or some other way to get in & remove the bulb. I appreciate your help. Tom
philcarr
11-04-2005, 11:44 AM
Tom;
I have an '05 Yukon which I replaced the rear tail light housing with a OEM Clear. It was very simple to remove. There are only 2 or 3 screws that need to be taken off which will allow you to pull the lens housing forward to get to the bulbs.
ETA for job is 5 minutes if that.
Denalix5
11-07-2005, 10:44 AM
To get to the screws you open up the tailgate and you should be able to see the screws holding the taillights in place. After removing the screws, pull the tail lights away from the body. It may take a little jiggling back and forth. Don't pull to hard or the wiring harness will get pulled out.
Good Luck
