Help Programing Remote For 2000 Chevy Blazerwb3032 05-24-2002, 10:15 PM I need help trying to program my 2000 chevy blazer keyless entry remote. The remotes that I have right now for it are model # GM P/N 12495653 and the new one that I bought to add on is model # GM/ LEAR 15043458. Thanks for your help Ben blazer_guy86 07-08-2005, 11:56 PM if you find out how to do this, i would greatly apprediate it if you would tell me too. i have a remote to a 2000 blazer but i own a 1998 blazer. i have been told they are compatable. if you can assist me in any way i would greratly appreciate it. thanx!!! hikick1 06-17-2007, 10:15 PM GM/ LEAR 15043458............I, too...needs the program code:) 03CavyMan 06-19-2007, 06:05 PM Sit in your vehicle with the doors closed. Press and Hold down the unlock button on the drivers' door, turn the ignition ON and OFF twice. Now release the unlock button on the door. The doors will now lock and unlock on their own. This means it's in programming mode. Now hold the UNLOCK and LOCK buttons down at the same time on the transmitter until the doors lock and unlock (usually takes about 5 seconds) now take the other transmitter and do the hold down the UNLOCK and LOCK button until the vehicle locks and unlocks again. Now turn on the ignition to the on position. You'll have to do both the transmitters at once, if you just do one, the other will not work. They all must be done at the same time. Good luck! :D Onblsht 06-20-2007, 12:28 AM You should definately have Part # 15732805 for a 2000 Blazer. hikick1 06-20-2007, 11:48 AM hi and thank you, I have a 2001 blazer with the id #I listed.....so they probably have the wrong remote.........But I have the correct one fopr my vehicle.....I needed the code for 4358............. Very observant of you I might add :) Hikick1 Onblsht 06-21-2007, 08:17 PM Programming instructions are the same for the 98-02 Blazer, Jimmy, Bravada models: Transmitter Programming: 1)With the driver door closed, hold down the power unlock button on the door panel. 2)Turn the ignition switch to the ON position 3)Turn the ignition switch to the OFF position 4)Turn the ignition switch to the ON position 5)Turn the ignition switch to the OFF position 6)Release the power unlock button on the door panel. The remote control door lock reciever will respond in the following manner in order to indicate that the receiver is in the programming mode: 6.1)Locking the doors 6.2)Unlocking the doors IMPORTANT: All extra transmitters must be programmed at this time. When a new transmitter is programmed it will deactivate the old transmitters. 7)Hold down the lock and unlock buttons on the transmitter until the remote control door lock reciever will respond in the following manner: 7.1)Locking the doors 7.2)Unlocking the doors 8)Repeat step 7 for each additional transmitter 9) Turn the ignition switch to the ON position in order to exit the transmitter programming mode. bullet1980 07-03-2007, 12:26 AM Hi, I tried doing the programing instructions on my 2000 blazer but i cant get the blazer to go into program mode vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
