How to replace fuel filter on 95 windstar?
summerman
10-29-2005, 10:05 PM
Is it hard for a newbie? Thanks a lot!
LeSabre97mint
10-29-2005, 11:27 PM
Depends on what you mean by newbie. You need to releave the psi from the system. Find the filter (usally by the fuel tank). Figure out what tools you need to get the filter off. I believe Ford uses the same tools that remove the airconditoning hoses. The cupplings are held together by a spring that requres a tool to spread the spring open so the fittings can be pulled apart.
I hope this gives you some idea. You will also have to deal with gas running down your arm when you get the line apart. I just did this job on my 97 LeSabre.
Why do you feel that you need to replace the filter?
Regards
Dan
DRW1000
10-30-2005, 10:15 AM
On my last three Fords with the high pressure fuel pump (IE fuel injected) I did not require the tool that is used on the fuel rails or AC for the fuel pump. I did not need this tool on my 99 Windstar either.
I agree that you need to relieve the pressure. (easy task) and deal with the fuel spillage on your arm.
12Ounce
10-30-2005, 12:08 PM
I recently bought an aftermarket fuel filter. The filter itself appeared to be OK ... but, luckily I noticed, the plastic clips were not what they should have been. They held the hoses connected to the filter ... but I could pull the hoses out of the connection by hand. This would not have been something I would want to be driving down the road with.
Now I wonder about the pressure rating of the fuel canister itself .....???
I'm never going to use an aftermarket filter again.
summerman
10-31-2005, 10:40 AM
Regards
Dan
Thanks for you detail info, I just bought this VAN recently, just wondering a new fuel filter can increase gas efficiency.
LeSabre97mint
10-31-2005, 12:50 PM
Hello
What I'm becoming more convinced that will increase fuel efficiency would be: Replace the O2 sensors at 60,000 intervolves, and having the injectors cleaned by ultrasonic and ballanced outside the engine. I'm going to try this with my 95 and see if I can get some more mpg out of it. I found a site that a business does this. What injector cleaner can't clean is the junk that builds up over time where the fuel doesn't touch. If the fuel doesn't touch it neither will the cleaner that's run with the fuel.
Regards
Dan
phil-l
11-01-2005, 08:47 AM
Hello
Out of curiosity: What business cleans and balances (removed) fuel injectors? If you've had this done before, were you pleased with their service?
Thanks!
LeSabre97mint
11-01-2005, 12:40 PM
Thanks!
Phil
I have not had my fuel injectors cleaned. I'm in the planning stage. I'm thinking about getting a second set from the bone yard and sending them in to get cleaned and ballanced.
I have the link at home so I will post it when I get home. The web site is very impressive and contains a lot of information..
Here is a site that cleans injectors.
http://www.witchhunter.com/
Search the web and there are others.
Dan
