Strange noise when coasting...shaff408 10-29-2005, 04:54 PM My '99 Escort ZX2 is making a strange noise. When at low speeds, and coasting, there is a noise/vibration that comes from the front wheel axle area. It's almost like you can feel the turning of the axle. Is this a transmission problem? AzTumbleweed 10-29-2005, 09:05 PM Have you checked the fluid level in the tranny? shaff408 10-29-2005, 09:10 PM I just had the transmission fluid changed about a month ago. AzTumbleweed 10-30-2005, 06:53 AM All the more reason to check it. sk8er4trix 12-08-2005, 06:54 AM this would be your ball joint is loose. wich is from havin a loose tie rod you can easily replace yourself, tierod and balljoint will run you bout $80, jack up yer car shake each tire and find wich one is loose. then go get the part n replace, this was my problem. before you buy the parts. when yer car is jacked up make sure your struts are tightly bolted to your mounts. loose struts will also make a noise but usually all the time and not just when coasting. Automotive Network, Inc., Copyright ©2012
