Originally Posted by abcabc
Two codes come up. 12 and 55 Do they mean anything to you.
12 = Battery has been disconnected in the last 50 key on cycles
55 = End of codes
So there are no trouble codes popping up...You replaced the battery and starter right? Did you check the starter relay? Try checking the relay by swapping it out with horn relay. After you put the starter relay in the horn spot, honk the horn. If it honks, it's good, if it doesn't, you will need to replace it.
Also check and double check for corrosion on the terminals or wires and make sure all the connections are REAL tight. The neon is real sensitive about this.
