Info display dimmingTonyr 10-29-2005, 11:39 AM I have a 98 GTP and the info area light seems to be dimming. The area where it shows the car, boost, range, and oil life.....The left side where the picture of the car is is pretty bright but the right side is about twice as dim. Has anyone had this problem and corrected it?? Thanks guys. BNaylor 10-29-2005, 01:38 PM I have a 98 GTP and the info area light seems to be dimming. The area where it shows the car, boost, range, and oil life.....The left side where the picture of the car is is pretty bright but the right side is about twice as dim. Has anyone had this problem and corrected it?? Thanks guys. There are 5 mini-lamps for illumination of the DIC. Checkout this old link which may be helpful and has a corrective procedure: http://www.automotiveforums.com/vbulletin/showthread.php?t=336441&highlight=dic http://i5.photobucket.com/albums/y186/lizzywiz/dic.jpg http://i5.photobucket.com/albums/y186/lizzywiz/gtp.jpg Thrasher CAI, DHP v1.0 PCM, SLP Headers, 3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT, u-bend delete, 160 TS, ZZP Stage 1 72mm TB, TB spacer, MSD 8.5mm wires, Autolite 103, Goodyear Gatorback Serp. & SC Belt, Nitto NT555R Drag Radials 1/4 ET: 13.210 sec. @ 104.490 mph 0 - 60 ft: 1.945 sec. Tonyr 10-29-2005, 07:31 PM Thanks, very informative. mrazekt2002 10-29-2005, 09:48 PM My is doing the same thing, but i figured it was just a design flaw. Thanks for bringing this up. :D troy1 10-30-2005, 12:49 AM I replaced mine with pc79 (Wagner) I think it was the same as the instrument cluster bulbs Tonyr 10-30-2005, 09:56 AM Troy, Where did you get the pc 79 Wagner bulbs? BNaylor 10-30-2005, 05:15 PM The instrument cluster bulbs are AC Delco L194 for that model Grand Prix. Sylvania 194 should be a match for those. Cost approx. $2.50 for two pack. Available at Autozone. Sylvania 2825 will also work. The Sylvania 2825 are 5 candlepower and a little brighter. The GM part number is 16151234 for DIC bulbs and come two to a pack. Cost is higher at approx. $4.75. For some reason Sylvania 24 rings a bell for DIC bulbs. http://i5.photobucket.com/albums/y186/lizzywiz/gtp.jpg Thrasher CAI, DHP v1.0 PCM, SLP Headers, 3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT, u-bend delete, 160 TS, ZZP Stage 1 72mm TB, TB spacer, MSD 8.5mm wires, Autolite 103, Goodyear Gatorback Serp. & SC Belt, Nitto NT555R Drag Radials 1/4 ET: 13.210 sec. @ 104.490 mph 0 - 60 ft: 1.945 sec. Tonyr 10-30-2005, 08:22 PM Thanks!!!! mrazekt2002 10-31-2005, 02:36 PM is there any way to change the color of the display? Tonyr 11-23-2005, 11:25 PM I replaced mine today. I had to get the pc74 bulbs because the original ones (pc119) were not in stock at NAPA, AutoZone, Fisher Auto Parts or the GM dealership in town. The bulbs were a little smaller but they light up pretty good. The job wasn't too bad at all. Thanks for your help everyone. BNaylor 11-24-2005, 12:33 AM The Sylvania #24 works just right and is the proper size which is in abundance at Autozone, Checker and Advanced. See below: http://www.clubgp.com/newforum/tm.asp?m=1079553&p=1&tmode=1&smode=1&cookie&cookieCheck=675549179&cookieCheck=675549179 Tonyr 11-24-2005, 11:13 AM I tried the bulbs that you said from AutoZone which were Sylvania 194 but they were too big and didn't have the blue base on them to turn back into the panel. It was just the bulb itself. So I ended up at Napa with the 74's they look pretty bright. Hopefully they will last a while. Thanks. BNaylor 11-24-2005, 11:27 AM I tried the bulbs that you said from AutoZone which were Sylvania 194 but they were too big and didn't have the blue base on them to turn back into the panel. It was just the bulb itself. So I ended up at Napa with the 74's they look pretty bright. Hopefully they will last a while. Thanks. At least you got it fixed. You misunderstood. I said 194 were the IP panel bulbs in reference to someone stating that the DIC bulbs were similar. At the bottom of my response I stated Sylvania 24. Sorry for the confusion. See quote below: The instrument cluster bulbs are AC Delco L194 for that model Grand Prix. Sylvania 194 should be a match for those. Cost approx. $2.50 for two pack. Available at Autozone. Sylvania 2825 will also work. The Sylvania 2825 are 5 candlepower and a little brighter. The GM part number is 16151234 for DIC bulbs and come two to a pack. Cost is higher at approx. $4.75. For some reason Sylvania 24 rings a bell for DIC bulbs. Tonyr 11-24-2005, 11:30 AM No problem, it looks like I read it wrong. You are a big help and I really appreciate it. Saves a lot of money doing it yourself than going to a shop! Automotive Network, Inc., Copyright ©2012
