hop ups for 92 s-10 (4.3)snotslinger 10-29-2005, 03:46 AM Got A 92 Chevy S-10 4x4 WITH 4.3 T.B.I..i Installed Duals With A Flowmaster Muffler And Gutted My Coverter.what Would You Install Next For More H.p. Without Major Tear Downs.i Have Been Looking At Chips What Ones Do You Like The Best.what About Drive Pulleys,do They Help.i Have No A.c. But Does Have Polution Pump Still Installed,can I Bypass.any H.p. Tech Tips Would Be Great. Thanks For Your Help. Joe O'bryan dmbrisket 51 10-29-2005, 03:21 PM a sb 350... no tear down, just a lot of work, with your tb under hood harness and ecm, you just need the moter OverBoardProject 10-29-2005, 10:30 PM You don't mention headers, so if you don't have a set start there. And those polution pumps drain power, and add extra weight to your truck. The headers might not even be plumbed for them And adding the chip will allow all the mods to work at their full potential Removing the polution pump might mess up with your oxy sensor readings, so you might have to trick this into reading right. If they introduce some sort of air care where you live you'll have to put everything back for your truck to pass, so don't throw anything out dmbrisket 51 10-30-2005, 01:48 AM headers :) automotives little basterd child :) dont even bother with headers unless you like the idea of getting under the vehcial every six months to replace the collector gaskets... OverBoardProject 10-30-2005, 02:08 AM I might be lucky Doug, I've never had problems with leaks when I've run headers. When I use the stock hardware I double nut everything, since the most header bolts seem to back off on their own dmbrisket 51 10-30-2005, 02:12 PM lucky... good job with doubbleing the nuts though, most people dont get the concept of the nut loosining iteslfe snotslinger 10-30-2005, 08:35 PM No Air Care Here.anyone Know If I Can Bypass The Pollution Pump With Out Messing Up E.c.m.. OverBoardProject 10-31-2005, 01:40 AM There is a good chance that who ever makes the chips or reprograms your computer can make arrangements for that. Just talk to them, and see what they say Automotive Network, Inc., Copyright ©2012
