Blend door - no heat
haze1956
10-28-2005, 08:24 PM
97 caravan,
Need to know if blend door is cable or vacuum operated.
haze1956
10-29-2005, 10:37 PM
Ok, Blend door wasn't the problem,
Van has some heat when idling but cools off as I drive it.
Thermostat ??
Opinions please
MT-2500
10-29-2005, 11:17 PM
Check coolant level first. Then go for thermostat.
MT-2500
vamc
10-30-2005, 12:31 AM
Sounds good to me
haze1956
11-03-2005, 10:36 AM
New thermostat in, had a little bit of heat for a day, now nothing.
I am thinking restricted heater core and want to flush it,
Problem is location of hoses, Crawled under car and there is one hose connected at the back of Water Pump, another into a T-shaped flange on opposite side of engine. Short hoses changing into piping running behind engine to firewall, not sure if these are to heater. Can anyone confirm if this is accurate.
Thanks
97 caravan, 3.3 V-6
haze1956
11-10-2005, 11:33 AM
Just amazed how useful posting on this site has been !! :rolleyes:
Ok, I have flushed heater core, minimal heat output now.
Anyone have experience with blocked airflow ?
Seems that when I switch blend door from hot to cold, airflow through vents dramatically increases.
Wondering is core is hot but low airflow causing lack of heat.
MT-2500
11-10-2005, 12:20 PM
Check hoses inlet and outlet going to and from heater core. They should be hot to the touch.
Also run the self diagnostic on your air and heater controls.
Any yellow lights blink on them?
MT
haze1956
11-10-2005, 02:23 PM
Hoses are hot and I'm getting some heat, but very little.
Checked computer and got no codes, just a 55
Or is there a different test to check the AC/Heating system?
MT-2500
11-10-2005, 04:31 PM
Sure is.
Try this.
MT
Let us know how it goes and post codes you get.
http://members.troublecodes.net/crunch/97car.pdf
haze1956
11-15-2005, 03:49 PM
I had previously tried a test holding compressor and rear windsheild buttons down. That left me with recirc. and compressor buttons flashing together when I start van. Stops after 10-15 minutes
When they stopped flashing, I tried the other sequence as described on Link you suggested. Van passed that test.
But still have other buttons flashing on start.
Any idea how to make them stop ??
MT-2500
11-15-2005, 04:16 PM
Print out the test and go threw them step by step.
To enter calberation you press rear wash and rearwiper buttoms for 5 seconds untill leds start flashing and the let it go threw the calberation.
MT
haze1956
11-15-2005, 04:37 PM
Did some additional research.
Apparently Van is passing the calibration test but failing the cooldown test.
Info I find is a Catch-22 ,
If both lights flashing, need to run cooldown test, which then ends with lights flashing.
Can't find any info for getting codes.
haze1956
11-15-2005, 04:59 PM
Sorry MT, I don't want to appear dense, but Test instructions are a little confusing.
I should run calibration test and when done, I do not exit it, but begin button sequences as described in test procedure ?
MT-2500
11-15-2005, 06:48 PM
If the rear wiper and inter wiper are flashing alternen there is a level one code.
If they are flashing together rerun calberation test.
Yes the test is confusing.
Just copy it off and go threw it step by step,
MT
haze1956
11-18-2005, 03:57 PM
Ran test several times
Level one - no codes
Level two - Flashing decreased when when selector moved to defrost and increased when back to panel.
Level three - Flashing slightly faster on hot than on cold
Level four - different flashes over different tests 7+5 / 6+6 / 6+4, I believe this is Temperature so that would be normal.
Still have recirc and a/c buttons flashing together meaning van failing cooldown test.
Suggestions Please !!
MT-2500
11-18-2005, 09:28 PM
You may have to get the dealer to check it.
Good Luck
MT
cyclonicblade
11-22-2005, 08:03 PM
Good Luck
MT
If Vac operated doors check for vac leaks also check for leaves or debri in heater core or ducts dont know if this will help but is first thing I look at in older cars
haze1956
11-22-2005, 08:19 PM
Pulled cover tocheck for blockage in fan, all clear, recirc door is sluggish but does reach both open and close positions
I can see A/C core from small rubber access hatch that temp probe wire goes through. Used compressed air to clean core, got some small debris out of vents.
The real problem I have is not knowing what is between the A/C core and the heater Core. I am assuming that is the Blend door location, which may be the casue of my problem. I can't confirm that it is reaching it's stops. I noticed the A/C wasn't working real well this Summer, felt cool but not cold. Now heat is warm but not hot. Seems to indicate I am getting mixed air.
Any idea where I might find a diagram of the Heat-AC system?
And now the cooldown test failure has the lights flashing fot 15 minutes every time I start the van.
Technology is good ? LOL
haze1956
11-27-2005, 10:48 PM
Think I have finally found problem,
I have constant outside air entering heating/AC system. This mixes hot air with AC in summer and cold air with heat in winter.
I finally figured this out by taping up the Air intake vents on the hood in front of the windsheild, I then got heat instead of cold air when Van was being driven with controls in heat mode. What little heated air that has been coming out, had been turning cold as soon as vehicle was in motion
Question is what controls air flow entry into the system, A door of some kind I am assuming, but where is it and what controls it.
There is a recirculation door in the passenger foot area, but this opens and closes by its control button yet doesn't seem to affect the intake of outside air.
Anyone familiar with the vehicle AC/Heat system?
MT-2500
11-27-2005, 10:56 PM
Here is a link to the best info besides a factory service manual.
http://www.alldata.com/products/diy/index.html
MT
holdemjunkie
11-28-2005, 10:01 PM
Replace heater core
haze1956
11-29-2005, 09:25 AM
If it were bad, that might be a good idea.
Did you read the previous posts ??
