2001 Grand prix gt coolant fan stays on all the timeroman1978 10-26-2005, 09:54 PM 2001 Grand prix gt 3800 motor coolant fan stays on all the time Hi can anyone help me with this problem my coolant fan stays all the time only shots off when the car is off. Took it to local mechenic he did some testing and told me that i need to replace my computer. Has any one had this issue and knows if there is something that can be done besides replacing computer. BNaylor 10-26-2005, 11:43 PM The PCM is the brain behind cooling fan operation. It references to the engine coolant temperature sensor (ECT) to determine when to turn on the fans. However, it controls a few relays which energize to control the operation of both fans. You can check to see if the relays located in the engine compartment fuse box are working correctly. If so, there is a high probability the PCM is the problem so the mechanic may be correct. http://i5.photobucket.com/albums/y186/lizzywiz/gtp.jpg Thrasher CAI, DHP v1.0 PCM, SLP Headers, 3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT, u-bend delete, 160 TS, ZZP Stage 1 72mm TB, TB spacer, MSD 8.5mm wires, Autolite 103, Goodyear Gatorback Serp. & SC Belt, Nitto NT555R Drag Radials 1/4 ET: 13.210 sec. @ 104.490 mph 0 - 60 ft: 1.945 sec. C6Chris 11-05-2007, 08:48 PM HI, I'm having the same problem as mentioned above. How to you check the relays in the fuse block? thanks BNaylor 11-06-2007, 07:46 AM HI, I'm having the same problem as mentioned above. How to you check the relays in the fuse block? thanks Hi, Please check the date and do not resurrect old threads. This one is over 2 years old so I'll have to close it. Start a new thread addressing your question or issue and we will be glad to help. Automotive Network, Inc., Copyright ©2012
