1998 Chevy S-10 headlight problem:
Mikey R
10-26-2005, 03:42 PM
Driver’s side headlight went down to just a glow, both dim and high beams.. I’ve tried cleaning a couple ground wires and putting in a new bulb but that didn’t work. Ideas?
OverBoardProject
10-27-2005, 12:29 AM
Clean the conection that plugs into the bulb.
If that doesn't work run a temp ground wire, just to see if the origional 1 is on it's way out
rlith
10-27-2005, 08:35 AM
Good advice...
blazer_guy86
10-31-2005, 02:47 PM
I had a simular problem on my 98 blazer. But on mine no matter if it was on high or low, all 4 lights (2 high and 2 low) would come on but a were all really dim. I had 2 fuses blown, one in the panel on the inside and one under the hood. In other worrds check fuses. Hope this helps you.
hlynn19751
12-30-2005, 10:12 PM
check your fuses
OverBoardProject
12-30-2005, 10:33 PM
check your fuses
This thread is 2 months old.
I would hope that he's had it fixxed long ago, and the fuses are hopefully 1 of the first things that he checked
