Any ideas on new system locationP11GT 07-31-2001, 08:39 PM My current setup is positioned on the left side of boot but this restricts my access to the spare wheel. Can anyone suggest a new location, anything except the rear of the back seats as its been done to death. I was thinking of installing both amps on the roof lining encased in a surround, with perspex, cooling fans and backlit with blue lights, so it can be seen when you look up sitting in the car. What d'you think? NismoG20 08-01-2001, 01:32 AM i like how u got ure amps mounted... can u tell me how u did all that cause i want to do that with mine... dude i would sooo much apreciate it... cause i think im adding another amp soon soo i wanna rack mine like that or somthing like that thanks BIG OOMP forever! download some stuff on MP3 its the shit! P11GT 08-01-2001, 09:40 PM To mount the amp(s) as i have above, firstly, you need to work out the size of the amp board you need by using a sheet of card board, then cut it out in 15 or 18 mm MDF. The board can then be covered in cloth of your choice, amps mounted into position, holes drilled for wires to pass thru, and then you need some metal L-shaped brackets to support the bottom to the boot floor (more drilling) and the back to the inner wheel arch at the top of the board. A bit hard to explain. Its easier than it sounds. MauiBlueGRide 08-02-2001, 05:17 PM I'd think you'd need to reinforce the roof with some fiberglass or something first to take the weight of the amps.... Plus running thick gauge wire up there would be a pain.... How about creating false floors in the rear of the car and mounting them there? (As in cutting portions of the floor out, mount a steel box underneat, and raise the floor in a few inches in the rear).... Never done it but seen it done, looks SWEEET... hehehe Idea #2, mount them under the rear tray with a motorized rack to either stick out when the trunk is open, or flip up..... (hey its only money right????) Later Chris P11GT 08-02-2001, 08:16 PM Thanks for the tip, but i think i'll go with the roof mount. Ive had a look and luckily, the sunroof is suspended and i can attach the amp rack to that. The wiring not too bad either, the rear quarter pillar upto the roof is double skinned and theres a large hole to allow wires to pass between the skins and upto where i wanna mount the rack. Basically, im gonna make the rack first , then install the amps from the rear so they are hanging into the rack, and finally finish it off with a MDF and perspex cover. Hard to explain, but give me a month or so, and i'll post some pics. endfro 08-06-2001, 02:15 PM MauiBlueGRide: If you like the way systems are done with the amps flush and a new trunk built in. Wait till you see mine. I was told yesterday that my two amps that are still in Phoenix are done and going to be shipped this week. The way mine is done is like this.. I have 3 amps, 2 of them are Xtant 2200ixR's, the other is a Xtant 1001dx. My sub box has 3 JL 12W6's. The outer subs are put at an angle from the center sub. They are pointing out towards the wheels. The 2 2200ixR amps are angled with the subs.. Those are flush mounted with the trunk. Above them, and only slightly over lapping is the much larger sub amp. I mounted that on a custom designed "shock protector". The amp rests above the 2 amps, and can take quite a pound, from bumps or subs. I'd draw it out.. but then you'd all laugh at me for trying to draw. :) P11GT 08-06-2001, 04:26 PM no... go on, i cant really picture it from the description you gave, so anything would help. The problem with making a false floor is that it will still restrict my access to the spare and i really need as much boot space as poss. Also, I own a fast food outlet and often use the boot to carry heavy stock, so the amps will get damaged. So far, ive managed to make the amp rack, and its off to get covered in vinyl tomorow, a sort of charcoal grey, which matches the original trim. The actual facia, that hold the perspex and covers the amps is gonna be sprayed in silver to match the dash. Im still working on the internal lighting, so far havent had any luck but it has been suggested to me that i should go to someone who makes neon signs and get a rectangle blue neon made to fit inside the amp rack. I'll get on the phone about that tomorow. endfro 08-06-2001, 05:04 PM http://www.webprogrammers.net/~qoshea/g20/g20.html You can go there for pictures of it before I sent two of the amps off. In that picture one of the amps (the sub amp) was already sent to Phoenix. P11GT 08-08-2001, 04:01 PM it looks nice but tell me, isn't that one of JL's boxes? its a bit too big for my boot. Anyway, the racks been covered in vinyl, 4 40mm fans have been installed to help cooling and im off to a local neon sign makers to get a neon made for the inside of it. When thats done, its ready for installation which should prove quite interesting. I haven't quite figured out everything yet but i'll come to that when i fit it. Its mainly making sure that its secure enough and can support the weight of the two amps, especially in the event of an accident. I cant get a hold of a Digi Cam so i can take any pics of the stages of manufacture, but i'll post some of the finished product later. Needless to say, ive spent many hours day and night, cutting, drilling, sanding it to perfection, and countless hours running around getting the bits and bobs for it. I hope its worth the hassle in the end. We'll see:rolleyes: T4 Primera 08-08-2001, 05:34 PM P11GT, It all depends whether you want the amps to be seen. Not sure about the P11 but in the P10 if you fold the rear seats forward there is a flap of carpet extending from the boot mat over the hump between the wheel wells. The carpet on the back of the seats attaches to this with velcro pads. Undo them and fold the boot mat carpet back and you find a plastic tool tray with some space next to it. This area forms a sort of hidden compartment which will have ample room for your amps and wont get in the way of anything or use up any boot (trunk) space. Your amps will be well hidden and protected in there. Have a look and see if the setup is the same as the P10. Happy Hooning:sun: P11GT 08-08-2001, 08:46 PM Thanks for that, my boot has a similar tool tray but it isn't that big, well not big enough for the size of my two amps anyway. I'm near finishing the amp rack now anyway, but i think the main factor as to why i chose to do it this way is to make it eye catching. Here are some pics of the nearly finishe product, ready for installation. P11GT 08-08-2001, 08:47 PM heres a front view. P11GT 08-08-2001, 08:51 PM In the top pic, you'll notice the cooling fans ive installed. These are 12 volt 40mm fans purchased from an Electronics shop. There are two on both side, one set drawing in air, and the other, expelling air, as once the rack is fixed onto the roof lining, it will be more or less air tight. The amps themselves, also have cooling fans built in behind a motorised sliding door, so this will aid the amps cooling and running at optimum performance. T4 Primera 08-08-2001, 09:04 PM And eyecatching it will be..... That looks sooo proffessional! How will you mount them whole thing to the roof so it doesn't break your neck in a crash? I thought if you remove the tool tray there might have been enough room. (I once saw an alpine amp mounted with 4 self tapping screws sticking thru the roof and a big cable up the middle of the windscreen!!) P11GT 08-08-2001, 09:16 PM Thank you. It took me ages to get thus far.:smoker2: My GT has a sunroof, and upon removing enough of the triming to look into the roof lining, i dicovered that the roof slides rear on two rails either side. These rails are suspended from the roof itself and have sufficient room to drill and tap the rack onto. I'm also gonna put metal brackets onto the rear side of the rack where its hidden and bend them around the sides, behind the roof lining and screw them to the bodywork, just behind the hand rails. If i put enough of these on, it should be more than secure, HOPEFULLY:D T4 Primera 08-08-2001, 10:13 PM Can't wait to see the finished pics:sun: Anthony 08-09-2001, 08:48 AM It's coming together nicely Kev :) P11GT 08-09-2001, 08:42 PM From the beginning, i was wanting to have the internals illuminated. Firstly, i thought of using neons but wasnt able to find anything that would fit straight in. I then enquired about having a neon specially made to fit but as i discovered, its quite costly. Ive now opted for LEDs ,not 10, not 20 or even 30 BUT 42 of the f*ckers! Reason being is that the rack is quite big, as you can see, so it needs a lot of LEDs to illuminate it. The problem is, each LED is 5.5 volts so i need to wire 3 LEDs in series and then wire each set of 3 in parallel. Each set of 3 give a combined load of 16.5 volts which is suitable to run on a cars battery without the use of resistors, or i would need 42 of them aswell. Anyway, the LEDs are on order, and im patiently waiting their arrival so i can get started on the huge task of soildering it all together. ITS GONNA BE FUN FUN FUN!!!:uhoh: P11GT 08-10-2001, 07:48 PM :D Here are some pics of the lighting complete. All 42 LEDs are now wired together into two wires, positive and negative. You wont be able to see the LEDs but you will see a blue glow around the amps. Nice?:D P11GT 08-10-2001, 07:49 PM more P11GT 08-10-2001, 07:50 PM MORE! T4 Primera 08-11-2001, 05:19 AM Awesome!!! Good Skills!!!:flash: P11GT 08-12-2001, 10:56 PM ITS DONE ITS DONE ITS DONE!!! Ive just spent a total of 8 hours installing the amp rack. Its now 3.50AM monday morning and ive just finished. Just need to install relay for LEDs and Fans, but everything in working order. I'll post some pics when i figure out why the Digi Cam wont download. P11GT 08-13-2001, 05:30 AM Heres some pics of the amp rack, just need to get some screws to fix the cover on. P11GT 08-13-2001, 05:31 AM more P11GT 08-13-2001, 05:32 AM last one, honest:D MauiBlueGRide 08-13-2001, 06:21 AM Looks sweet man - congrats! Chris b-b00gie 08-13-2001, 09:00 AM Nice!!! Looks great, and clean... (just hope it never falls down on anyone!) :eek: P11GT 08-13-2001, 04:39 PM Originally posted by b-b00gie Nice!!! Looks great, and clean... (just hope it never falls down on anyone!) :eek: Yeah,:D i share your thought, i didnt get as many screws to fix it in place, as i would have liked, but nevertheless, i can grab the rack and rock the whole car with it, and thats with lowered springs, so hopefully, it should be secure enough P11GT 08-15-2001, 08:40 PM heres a pic, but what is it?????? P11GT 08-15-2001, 08:42 PM the above picture, is in fact the three centre LEDs ive install on the amp rack just for extra effect. Heres another also taken at night. I will shoot some in the morning and post them. its now completed, and functions normally as before. jgolomb 07-08-2002, 03:18 AM You may want to do some serious re-consideration in regards to your mounting location. What you've put together so far looks really sweet but cooling is going to be a problem for you. Yes, I saw where you have placed the fans - good idea - but your amps will be mounted upside down - bad idea. The amp disipates off the circuit board into and through the heatsinks, heat rises as we all know therefor you are eliminating the function of the heatsink by having them upside down and things are gonna get hot. this may not be an immediate problem but it will severely shorten the life span of your amps and won't take long to become an issue. I've been installs for a long time and just don't want to see so much good work turn into something not so good. heat is always an issue, I've seen a lot of hookups where people didn't take it into consideration or simply said 'screw it' and 9 time times out of ten sooner or later there's a problem. Not trying to rain on your parade, just really want you to be sure of the situation that will probably turn into a hot one and put some more thought into it. Perhaps there's a way you can mount the amps right-side up so as not to lose the heatsink function - that would really help! Just my two cents... - Jeff P11GT 07-08-2002, 11:21 AM So far, the installs been in about a year now, and ive had no problems with the heat. The amps itself have a built in fan which would also aid cooling. But remeber, the transistors ( i thnik they are called) anyways, the bits that actually create the heat in an amp are usually secured onto the heat sink inside the amp, so an heat would transfer into the heat sink regardless of it location. Convection normally travels upwards, as you say heat rises, but conductivity travels in all directions, and thats what were dealing with here. So once the heat is in the heat sink, the fans will covect it away. P11GT 10-31-2002, 08:32 PM <bump> Automotive Network, Inc., Copyright ©2012
