alternator or whatcamaroislove2me 10-26-2005, 01:46 AM I need help I just replaced the alternator on my 91 jeep cherokee sport and I am still ahving a problem holding a charge, can anyone tell me where the voltage regulator is or what might be the problem? 89ltd 10-26-2005, 01:54 AM im quite sure the voltage regulator is built into the alternator, your battery could be bad or something is putting a constant drain on the battery. Do you have a volt meter? What is it charging at now? theFREAKnasty82 10-26-2005, 06:43 AM in 1991, Jeep finally conformed to Chrysler electronics, so therefore your voltage regulator is housed inside of the PCM, or engine computer. If it's bad, you'll have to replace the PCM. Dominic240 10-27-2005, 05:54 PM check all your ground connections. How are the battery terminals? Automotive Network, Inc., Copyright ©2012
