Originally Posted by DobeMax587
Thanks for the reply.
The road was an old rural paved highway (hardly any pavement left) and it was soaking wet. I was just trying to see if the 4 wheel drive worked because I had not tried it out since I bought it. Is it ok just to see if 4x4 works in that type situation (wet pavement)? If not does it harm the vehicle if it was just driven a short distance? Less than half a mile total.
Thanks again for the quick reply,
HP
Yes, wet pavement is ok - it usually lets the tires slip and release the tension before it gets too bad. People get a pop or clunk from the front end when the windup releases - but grinding noises are not normal.
Doesn't sound like you are too familiar with 4 wheel drive. You may be hearing a normal noise, but since it is under warranty you might as well get it checked to be sure.
You should not get a pop or clunk when testing on a dirt road - the tires will slip the tension off. No grinds either.
