91 Nissan Sentra Cooling System HELP!!melcov 10-25-2005, 07:12 PM I need a diagram of the cooling system for my 91 sentra. I need to locate the cooling fan relay and switch. My fans will not kick on even after idling for a good while...so please help!! I've been told where to look and I can't find them so I need to be shown... Boogieman142 10-26-2005, 02:05 AM here is for the 2.0 http://i28.photobucket.com/albums/c216/Boogieman142/2.gif here is for the 1.6 http://i28.photobucket.com/albums/c216/Boogieman142/1.gif as far as the switch goes, the pcm turns it on. melcov 10-28-2005, 09:54 PM Hey thanks alot man...that was the thing that I was looking for!!!! as far as the PCM?? I know what it is but can it go bad?? Can I check that?? Boogieman142 10-28-2005, 10:12 PM Hey thanks alot man...that was the thing that I was looking for!!!! as far as the PCM?? I know what it is but can it go bad?? Can I check that?? They sure do go bad, just like any other electrical component. The pcm uses a ground switch to turn on and off various components. To test it, Find the wire going from the pcm to the fan relay and hook a test light into it with the test light getting power, and the ground through the pcm. Leave the car sitting a while and the light should turn on at the time that the fan turns on. if it doesn't then there is a problem between the relay and the pcm. Automotive Network, Inc., Copyright ©2012
