swift will not startampps 05-23-2002, 11:34 AM i have a 1994 1.0 litre suzuki swift with 118,000 miles on clock, my problem is my car works fine if i use it everyday if i do not use it for even one day it will not start, it might start with jump leads it might start an hour later or the next day.(it has a new battery) any advice would be most welcome thank you. sjorrie 12-26-2003, 02:23 PM Hi ampps remove youre airfilter then you see a black thing that's youre throtlle body when tuning the ignition key tab it with a screwdriver (not to hard) and in most cases the car wil start solution is to use some injector cleaner. Good luck SYDNEY10 01-20-2004, 07:39 AM I just put a can of throttle body cleaner through my carb and now it idles better and milage is much better. Automotive Network, Inc., Copyright ©2012
