Spongy/no brake pedalbeerice 10-24-2005, 09:16 PM While driving the other day had to slam on brakes to keep from hitting an idiot... After that little to no brakes... Last time this happened changed several parts and sending to dealer before I figured out it was a brake vacuum booster problem... Changed that again this time.... Did not fix problem.. Also found a sticking caliper this time.. Changed this also... Now Brake pedal travels almost all the way to the floor with little to no stopping unless pedal is jammed to floor causing ABS System to kick in and then car will stop... System has been bled NUMEROUS times... No air is coming out... Any ideas... I am so fed up with this Malinbu POS!! gapboi210 10-24-2005, 11:47 PM Sounds like your problem has never been fixed right the first time. Check the back brakes, might need to be adjusted or need brake cylinders. beerice 10-25-2005, 07:54 AM pretty good observation... The dealership has no clue about it.. cost me 150 for them to "Fix" the brakes..Which consisted of them bleeding them.... Fixing nothing... My repair manual says that now they need to be hooked up to the "Scantool" to be auto bleed, but the dealership knows nothing about this,,, maxwedge 10-25-2005, 09:53 AM The dealership can't use the Tech 11 scanner to bleed the abs, where are they on Mars, this is std practice, 150 no fix, I'd be in the SM's office. Automotive Network, Inc., Copyright ©2012
