Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Honda > Accord/TSX/Accord Hybrid
Old 05-23-2002, 10:20 AM   #1
4GZChatch
4GZChatch's Avatar
4GZChatch Normal reputation
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
Accord questions
Hey guys, My wife's accord has just turned over 75k miles, and the "maintenance required" indicator came on. Can anyone tell me what the required maintenance is for 75K? Also, can anyone tell me how to switch the indicator back, or reset it? I drive an 89 civic hatchback, so I don't encounter these things. Thanks for the help!
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
4GZChatch is offline   Reply With Quote
Old 05-23-2002, 11:22 AM   #2
92Accord92
92Accord92
Send a message via AIM to 92Accord92
Usually there's a slot for you to insert your key right below or near the indicator itself.
92Accord92 is offline   Reply With Quote
Old 05-23-2002, 12:38 PM   #3
HONDA_99
HONDA_99 Normal reputation
That applies for 4 & 5 gen Accords (90-97).
For 6gen Accord (98-02), you have to press and hold trip odometer reset botton for 10sec with ignition key in "ON" position (engine not running).
HONDA_99 is offline   Reply With Quote
Old 05-23-2002, 10:31 PM   #4
thewoahna
thewoahna's Avatar
thewoahna
Send a message via AIM to thewoahna
You need to change Timing belt, and it would be a good idea to change the water pump too. Also, make sure that all fluids are good.
Whenever at a loss of words, "Woah Na!" will suffice....
AOL IM: WoahNa316
Click here for some of my car pics/stats
thewoahna is offline   Reply With Quote
Old 05-24-2002, 12:17 AM   #5
strodda
strodda
my old reliable '91 has hit 129k. besides checking the timing belt, and water pump/hoses, what else should i have checked? if anything, other than the fluids. a couple months ago i got a new radiator(new coolant of course), so i dont have to worry about that.
but is there anything else?
thanks.
strodda is offline   Reply With Quote
Old 05-24-2002, 08:16 AM   #6
sk8erchick815
sk8erchick815
Send a message via AIM to sk8erchick815
Usually, at 75,000 miles, you're supposed to get a full car check-up, however, I don't know if that's why your "maintenance required" light is on. Hope I helped.
Hondas kick serious ass!
96 Accord LX
sk8erchick815 is offline   Reply With Quote
Old 05-24-2002, 08:42 AM   #7
93speed
93speed's Avatar
93speed
My manual says change the timing belt every 90k....
93speed is offline   Reply With Quote
Old 05-24-2002, 02:41 PM   #8
brads94accord
brads94accord
Send a message via ICQ to brads94accord Send a message via AIM to brads94accord
yeah, i got my big tune up at 90k miles, timing belt, water pump, and everything. the total bill was around $900
representin old school ph since april 2001, formerly UGAbrad94Accord
311 rules!
94 accord lx
16" konig reigns
3.25 inch drop on sprints and bec-techs.
clears all around, intake, custom rear section exhaust
farenheight plasma xenon headlights
click for my website
brads94accord is offline   Reply With Quote
Old 05-24-2002, 03:20 PM   #9
wagsaccordsir
wagsaccordsir's Avatar
wagsaccordsir
Check this out, your maintenance required light as you say is actually just a switch that flips through 3 colors, green to yellow then to red.. All it means is that you need to change your oil and check all your other fluids.. Your check engine light however means you have a fuel or an emissions problem, usually just a sensor.. As far as the 75k thing, yea you should change your belts, but heres a better way to go about it then going somewhere and having them rob your pocket..Go to your nearest Honda dealers service department and ask for a list of all the maintenance requirements for the life of the vehicle.. It breaks it down from the time you buy the car, until about 175,000 or so.. I.E. 3000, 7500, 15000, 30000, 45,000, 60000 and so on, this little chart will tell you what is recommended at each level of milage.. Hope this helps ya and saves ya some money in the long run.. Some will tell all kinds of crap needs to be done when in actuallity it does not... Email if you got any more questions, I'd be glad to help...
wagsaccordsir is offline   Reply With Quote
Old 05-26-2002, 02:12 AM   #10
skeefree
skeefree
Send a message via AIM to skeefree
I just got mine taken in with 112K on it, and they had to replace the radiator and the brake lights. Has anyone had their brake lights go out on them? I've replaced mine more than once, both times at over 90K. Does this seem really odd or did I just get the shaft?
skeefree is offline   Reply With Quote
Bookmarks
Google
Web AF
