oil leak onto exhaustPreviaLE in SJ 10-24-2005, 05:48 PM I have a 92 Previa LE that appears to be leaking from the cam cover. I have replaced the cover gasket and the o-ring around the distributor but it still leaks. Thanks for any suggestions. Bruce D.H. 10-27-2005, 12:51 PM I had a similar problem. The cover itself was warped. You can lay it on a piece of glass for a primative test. If it is obviously warped that will tell you. Could be just bad enough to leak and not show so it is not fool-proof. Mine still leaks, but it appears the feeder from the oil reservior is leaking and flows onto the cover and the exhaust. 329,000 and going. Automotive Network, Inc., Copyright ©2012
