Jeep Cherokee Sport Door Speakersrhjaeger 10-24-2005, 04:45 PM In both my 1998 and 2000 Jeep Cherokee Sport the speakers in the LF door went dead. In both cases I found a factory splice that went bad. The splice was in the wiring harness that passes through the "boot" from the door to the body. Who ever heard of a splice in an area where the wires flex? I ran a new wire to fix it. I have a copy of the wiring diagram if anyone needs it. Contact me with your fax number. Rich ejfenz 10-25-2005, 08:15 AM Man, the same thing happened to our 98 Sport. I had to cut and splice the passenger side speaker. I also have issues with the gas gauge sending unit. ...nice jeep other than that. I'm still looking for a reply to anyone that swapped the bench seat with one with headrests. gregory914 10-30-2005, 08:50 AM Just bought a 98 Limited and the drivers side speaker is not working would you please fax or e-mail the diegram to me at (440) 349-4804 or gvmedesign@aol.com. Thanks, Greg pylonbiker 10-31-2005, 09:05 AM In both my 1998 and 2000 Jeep Cherokee Sport the speakers in the LF door went dead. In both cases I found a factory splice that went bad. The splice was in the wiring harness that passes through the "boot" from the door to the body. Who ever heard of a splice in an area where the wires flex? I ran a new wire to fix it. I have a copy of the wiring diagram if anyone needs it. Contact me with your fax number. Rich hi Rich not only have the front speakers died on my 98 cherokee but now there's no spark from the ignition coil. I would love a copy of the electrical schematics. Thanks. fax 604 298 7608 e-mail pylon@telus.net jdsalas 10-31-2005, 10:05 AM I don't have a fax but could you e-mail it to me at jess2685@gmail.com? Thanks Alot AlohaBra 11-06-2005, 02:31 AM In both my 1998 and 2000 Jeep Cherokee Sport the speakers in the LF door went dead. In both cases I found a factory splice that went bad. The splice was in the wiring harness that passes through the "boot" from the door to the body. Who ever heard of a splice in an area where the wires flex? I ran a new wire to fix it. I have a copy of the wiring diagram if anyone needs it. Contact me with your fax number. Rich **************************************** Great post ....power window problems can also be traced to this part of the harness...you will need to pull on the wires because the break is inside of the insulation. Start by taking the door panel off. AlohaBra 11-06-2005, 02:40 AM [QUOTE=ejfenz]Man, the same thing happened to our 98 Sport. I had to cut and splice the passenger side speaker. I also have issues with the gas gauge sending unit. ...nice jeep other than that. On the gas gage sending unit...they have new version for that...on my 97XJ, it was recalled by the manufacturer. You are lucky....so far. tblack 11-09-2005, 09:46 PM [QUOTE=rhjaeger]I found a factory splice that went bad. The splice was in the wiring harness that passes through the "boot" from the door to the body. I wish I would have read your report before I just dropped $300 bucks replacing the radio. At both the JEEP dealer and the stereo shop where I eventually ended up said my lack of right door speaker in my 2000 Sport was due to a bad right channel in the original radio unit. JEEP wanted $850 for a new radio with installation. The stereo shop replaced my original unit with a pretty nice Alpine model CDE 9843 that sounds better, but during the install they said they found the right speaker did not work with the new unit. They found that bad wire you speak of and ran a new one. I could have done that myself in a couple of hours for about $0 because I am an audio/visual specialist by trade. I should have known better. tb FlatLanderHandicap 11-10-2005, 03:15 AM [QUOTE=rhjaeger]I found a factory splice that went bad. The splice was in the wiring harness that passes through the "boot" from the door to the body. I wish I would have read your report before I just dropped $300 bucks replacing the radio. At both the JEEP dealer and the stereo shop where I eventually ended up said my lack of right door speaker in my 2000 Sport was due to a bad right channel in the original radio unit. JEEP wanted $850 for a new radio with installation. The stereo shop replaced my original unit with a pretty nice Alpine model CDE 9843 that sounds better, but during the install they said they found the right speaker did not work with the new unit. They found that bad wire you speak of and ran a new one. I could have done that myself in a couple of hours for about $0 because I am an audio/visual specialist by trade. I should have known better. tb Audio/visual specialist and you couldnt install the radio yourself??? or locate the problem area yourself? tblack 11-10-2005, 11:27 PM Audio/visual specialist and you couldnt install the radio yourself??? or locate the problem area yourself? A shoemaker's children go shoeless. A housepainter's house never gets painted. A Doctor smokes cigarettes. A master mechanic drives the oldest ugliest car. An audio/visual specialist never bothers with his own AV because he is too busy taking care of everyone elses. tb sklater 11-12-2005, 01:10 AM kinda similiar, but speaker in the rear. The other day I was going to put new speakers in my 98 sport, rear speakers. When I had the radio on and took off the coverings, the passenger speaker did not work. Now, the driver side did work, so I took that speaker off and hooked it up to the wires in the passenger side, but no sound, so I hooked that speaker back to the driver side. So, not a blown speaker for I tested that speaker as well. Do I need to replace all the wiring for the rear speakers to get it to work properly?? That's a lot of wires and time spent gutting the interior to get to the wires. bmwgolfguy 08-16-2007, 01:06 AM For what its worth, I purchased two 01 Cherokees this year and both vehicles had front speaker issues. I also drove many others that vintage and most had speaker issues (as in not working). In my case, both were wiring problems where connections to speakers were bad. I think this was a major problem with these particular vehicles. So just rewire them. That will fix the problem. As long as you're at it with the new wires, you might consider replacing the spearkers as well, as long as you have the door panel off. The speakers themselves are mediocre for sound at best. Just my :2cents: . Good Luck! dave92cherokee 08-16-2007, 12:27 PM You should not revive a post that is 2 years old. The problem has probably been fixed by now in some way or another. phrenic13 08-18-2007, 03:00 AM glad this post was revived. when i bought my 2000 the passenger side front speaker did not work. i decided i wanted to replace the stereo and all four speakers and the passenger side front still does not work, so i figured it was a wire. i think im gonna try to fix it tomorrow. i have actaully heard it work a couple of times and it made a world of difference. thanks Saudade 08-18-2007, 10:14 AM Please pay attention to the posting dates. As Dave said, please don't revive threads long dead. Especially if you have nothing significant to add to them. If you feel you must, then create a new thread and link the old one in it. phrenic13 08-19-2007, 03:34 AM i see nothing wrong with someone reviving an informative post. i checked out my passenger front speaker and noticed it was spliced in the rubber boot between the door and the body. the plastic on the connecter was dry and cracked which caused the wire to short. i just found it easier to run a new wire from the stereo to the speaker and now it works great. meganleighhh 08-19-2007, 05:26 PM i just bought my '99 cherokee and the power windows only work from the drivers side. my front speakers also dont work. that helps explain my problems. now to get them fixed.. =/ jjklug 08-28-2007, 02:06 PM Again...a '98 Cherokee Sport. The one odd thing about mine is that both front speakers went at essentially the same time. I was told it was the internal amp...and bought a new deck. Obviously the new deck still did not pick up the front speakers, and that is where I am now (returned the new deck to bestbuy this morning. I suppose the next step is to tear the door apart to check out the "faulty wiring" that all of you speak of. Also, this "wiring diagram" would be appreciated as well. (519) 894-3732 or jjklug@rogers.com. Thanks for all the help. xr3dcrunkx 08-17-2010, 04:48 PM sorry to be "that guy" who comments on a post 5 years later but i was wondering if i could get that wiring diagram. i would much rather have that then rip stuff apart or cut and gut like a prehistoric caveman. my 99 cherokee had one speaker go out but would work if you cranked the volume up nice and high then it stopped working all together. then the second front speaker went and i knew it was wiring after i purchased new speakers and they didnt work. is it easier to run a new wire all the way from the cd deck through the dash and door or can i just find some mystery connector in the boot to rewire? any advice would be great.:icon16: you can contact at chrisflinsky@hotmail.com Automotive Network, Inc., Copyright ©2012
