'98 Pathfinder - Power door locks and windows fuse?algae 10-23-2005, 06:09 PM Hi all, Just trying to locate the fuse(s) for these. Can't find the in the box under the dash or the hood. Am I missing something? Thanks for any help. Gary P.S. Perhaps to further explain what I am up to. Neither the locks or windows will work from inside the vehicle. However door locks will work with the remote control. G. FixUrNissan 10-24-2005, 06:48 AM Hi all, Just trying to locate the fuse(s) for these. Can't find the in the box under the dash or the hood. Am I missing something? Thanks for any help. Gary P.S. Perhaps to further explain what I am up to. Neither the locks or windows will work from inside the vehicle. However door locks will work with the remote control. G. I would check your main window switch .. also see if power door locks work form pass side switch.. all Windows are inop? then you might want to look further. If you have a test light , check all fuses and see if any are blown. Start there first if you have a test light . If you don't i would take it to someone who is qualifyed in fixing it for you. Or you can just give me more info and i certainly will give it a shot :) algae 10-24-2005, 07:38 AM I would check your main window switch .. also see if power door locks work form pass side switch.. all Windows are inop? then you might want to look further. If you have a test light , check all fuses and see if any are blown. Start there first if you have a test light . If you don't i would take it to someone who is qualifyed in fixing it for you. Or you can just give me more info and i certainly will give it a shot :) Thanks for replying. The door lock will work from the passenger side but not the window. I don't have a test light , but I can visually check all the fuses. However I'm still confused as to exaxtly which fuses are for these locks and windows. Gary Automotive Network, Inc., Copyright ©2012
