Water Pump Stuckchaos18000 10-22-2005, 10:08 PM I got the 5 bolts off and the water pump is stuck to the motor, i wasnt sure i should hit it with a hammer or just pull at it. Well the pulling didnt work. Dunno is there something i can use to break the seal? maxwedge 10-23-2005, 12:20 PM Make sure you don't miss one hidden under the pulley, tap the w/pump housing at the pulley flange, should loosen up. bobss396 10-24-2005, 12:51 PM Put a couple of bolts loosely back in before you rap on it, so it doesn't fall off and break something. Use a soft hammer or a hammer and a piece of wood. Automotive Network, Inc., Copyright ©2012
